It is currently Mon Jun 15, 2026 2:48 pm
 Post subject: HEI wires
PostPosted: Sun Mar 23, 2008 5:27 pm
I went to the junkyard today with The Other Rob and we pulled a module to do the HEI conversion. We ended up pulling one of the GM all-in-one types off a 97 S-10. Now, in the HEI article it says to get an appropriate coil-to-distributor cap wire because of the differences in the ends, however how do I figure out what the appropriate coil wire is?
I think the rain and cold have sludged my brain up.. time to sit next to the heater to dry out and have a beer.
<i>D'Artagnan</i>
<img src="http://img.photobucket.com/albums/v432/stephaniexchaos/dart/th_IMG_0326_zpsumhhfxi0.jpg">
PostPosted: Sun Mar 23, 2008 6:21 pm
A 1997 HEI module would be for computer controlled timing. This page in the Megasquirt manual has pinouts for a lot of common HEI modules. I'm assuming you are not in fact using some sort of computer in combination with the HEI system, in which case you'd leave the E, R, and B pins disconnected.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Mar 23, 2008 6:51 pm
It's not the pins that I'm concerned about, it's finding the correct coil-to-distributor spark plug type wire. I'm not sure which application to go by, and was hoping somebody could tell me. Do I need the coil-to-distributor wire that would ordinarily go on the 97 S-10? Or can I just use a universal type wire? Or something different than either one of those?
<i>D'Artagnan</i>
PostPosted: Sun Mar 23, 2008 8:52 pm
Not necessarily. The 4-pin module was used up through at least 1997 in some applications; see discussionhere.
Stephanie, a coil-to-distributor-cap cable from any 1991 or later Chrysler Corp vehicle that used the compact E-core ignition coil will work. This includes all the 2.2 and 2.5 litre 4-cylinder cars (Shadow/Sundance, Spirit/Acclaim, LeBaron, Voyager, Caravan...) as well as Dakota pickups and others. That coil looks like this:
PostPosted: Sun Mar 23, 2008 9:03 pm
Thanks Dan! All these parts mixing around gets to be too much sometimes and I wasn't sure which cable would connect the GM module and the Mopar distributor cap. I'll head down to the parts store tomorrow.
<i>D'Artagnan</i>
PostPosted: Sun Mar 23, 2008 9:45 pm
Car Model: 1967 Dodge Dart GT
sorry to hijack this topic, but im confused about this cable, i just have the stock cable from my dist to my coil, should i have upgraded?
PostPosted: Sun Mar 23, 2008 10:17 pm
Go scroll through the HEI upgrade article, and you'll see the GM combination module/coil assembly Stephanie's using. It includes a coil with a male output terminal rather than the female type used on our stock coils and many replacements.
Stephanie, you'll likely find you can't get just the coil wire; they'll want you to buy a whole set of plug wires. If that's the case, and you don't feel like arguing, specify a wire set for a 1992 Dodge Spirit with 2.5 litre engine. Turbo or non-turbo, same wires. But actually, having said that...how long of a coil wire do you need?
PostPosted: Sun Mar 23, 2008 10:36 pm
ok, gotcha, im running an accel super stock, so not an issue for me, thanks for the clarification!
PostPosted: Mon Mar 24, 2008 3:31 am
What ever wire you have running from your coil to the center post of your distributer cap now is fine. The wires you need to make go from the + and - of the coil to the HEI module and to the 2 wires on the MOPAR electonic distributer, you did get one of those too right?
PostPosted: Mon Mar 24, 2008 5:13 am
i put in a later motor so have elec ignition already, i did the hei conversion working just fine, i just wanted to make sure i hadnt ignored something basic somehow. thanks!
PostPosted: Mon Mar 24, 2008 5:14 am
Stephanie,
I have one of the wires you need. I got it as an extra in a ebay deal, and would be glad for you to have it...is $2 to much? I am using an E core solid state coil is why I needed that kind of wire, so got 2 of em.
rock
'64d100
PostPosted: Mon Mar 24, 2008 6:08 am
Interesting. I looked up the wiring diagram for a 1997 and it turns out that it was computer controlled - but GM was using the computer to imitate the trigger signal that a 4 pin module would get. So this would make the S10 module a sort of weird hybrid - it's a 4 pin module that has been placed under computer control.
PostPosted: Mon Mar 24, 2008 7:18 am
Get a spare. No joke. I have NEVER had any good luck with any Accel products, save for their wires. When I first did the HEI conversion, I used an Accel module and it didn't even last 200 miles. I had to have my buddy tow me back to the base with his pickup after our squadron picnic :evil:
PostPosted: Mon Mar 24, 2008 7:29 am
weird, my dart had one when i bought 5 or so years back, and so far no problems at all, i picked up an extra one on clearance at autozone for 10 bucks, but now its in my hornet, ive got a msd blaster 2 around here somewhere i pulled out of a jeep truck for a few bucks, maybe ill take it back to school for a backup for the hornet...
edit:i realize now youre talking about the hei module, im talking about the coil, i am running whatever part number the hei module is at napa
PostPosted: Mon Mar 24, 2008 7:55 am
...except for the minor problem that it won't fit.
Users browsing this forum: Ahrefs [Bot] and 3 guests
