It is currently Thu Dec 25, 2025 2:14 am
 Post subject: soft pedal, sorta
PostPosted: Mon Mar 24, 2008 11:56 am
First I have a 70 dart custom that I just got, on the way home with it a brake hard line ruptured, a quick trip to a friends shop fixed that. Since then every now and again while sitting at a light the pedal would loose pressure and sink to the floor so I bled the brakes thinking the problem was just air in the system. Now if I hit the pedal hard it holds pressure just fine but if I let up just a little it looses all pressure and sinks to the floor, also if I slowly easily hit the pedal it'll go right to the floor, so now I'm thinking master cylinder? Any other ideas? Any help would be greatly appreciated. Thanks, Dave
PostPosted: Mon Mar 24, 2008 12:13 pm
I'd look real hard at the master cylinder, then at all of the lines and wheel cylinders for any signs of leakage. Make sure you look under the carpet around the master cylinder / pedal area.
PostPosted: Mon Mar 24, 2008 12:19 pm
sorry, I should of mentioned that, there's no apparent fluid leak, master cylinder level isn't going down at all
PostPosted: Mon Mar 24, 2008 1:19 pm
Your symptoms are right on for internal master cylinder leakage.
PostPosted: Mon Mar 24, 2008 4:31 pm
Yes... Master Cylinder is bad. I had EXACTLY the same symptom, sinking pedal at stoplight, solved it with a master cylinder replacement.
BTW - It took my two tries to get a good rebuilt master from the auto parts store. The first one did the same thing as the bad one.
-Mac
PostPosted: Mon Mar 24, 2008 4:45 pm
Yup, bad master cylinder.
Don't drive it in this condition unless you want to cause a rear-ender, and a big law suit.
PostPosted: Mon Mar 24, 2008 6:59 pm
or you get get at pumpin the brakes, i drove my valiant wit a crap MC for a few months... no dings
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
 Post subject: Maybe
PostPosted: Mon Mar 24, 2008 7:14 pm
The best thing to do is just set the car on fire?
Just kidding! Hi Dave! Good luck at the parts counter this week.
(Dave is my buddy and a hardcore chebby refugee!)
radar
madam im adam
 Post subject: Re: Maybe
PostPosted: Mon Mar 24, 2008 7:52 pm
radar
if we set my car on fire we can use the air filter for your demon, that'll fix it, right?
PostPosted: Mon Mar 24, 2008 7:58 pm
Thanks guys, I figured it was the master but wanted another opinion just to be sure. I guess it's off to advance after work tomorrrow
Users browsing this forum: Ahrefs [Bot] and 5 guests
