It is currently Sat Oct 24, 2026 2:40 pm
 Post subject: battery cable
PostPosted: Mon Nov 11, 2002 5:01 am
the battery (pos) cable on my wife's 74 swinger/6 is bundled with the wire for the starter solnoid. where can i get a new one? or what is the preffered method of replacement.
thanks
PostPosted: Tue Nov 12, 2002 8:05 am
Wow, no-one knows this? what do ya'lls guys positive cables look like?
PostPosted: Tue Nov 12, 2002 8:18 am
I think you can get the battery cable, with the smaller wire from one of the better parts stores: ei: NAPA, Carquest, etc. Two other options are, get a cable wich has a small "pigtail" and butt splice your wire onto the pigtail, or Put a ring terminal on your small wire, put it under the nut for the clamp bolt. The first method is prefered. :)
 Post subject: Battery Cable Info.
PostPosted: Tue Nov 12, 2002 8:55 am
Seems to me that most auto parts stores have these.
They do not look like the OEM cable but will do the job.
Many time I can save an OEM cable just by splicing-on a new terminal end, the auto parts stores have a lot of this stuff.
If the at stock cable is completely shot, you can split the harness and reuse the smaller wire with the new cable.
I bet if you really search around, someone out there has an NOS or Repop replacement cable close to the factory part.
PostPosted: Wed Nov 13, 2002 4:34 am
thanks, i went ahead and put on a new terminal but that looked like it was gonna be the last time lengthwise. I tried all but Napa. will go there next.
Users browsing this forum: Google [Bot] and 11 guests
