It is currently Thu Jun 18, 2026 7:55 pm
PostPosted: Sat Nov 09, 2002 8:13 pm
i have 2 volares and one has the 8 1/4 rear. will they work in an early A body? ie, are they too wide?
thanks again
PostPosted: Wed Nov 13, 2002 8:20 am
I don't know if the Volare rear is too wide, but I know that its wider than an A-body rear. You also might have to move the spring perches to use this rear in your Valiant. Hopefully, someone else will know for sure.
'78 Volare 225
'67 Charger 318
PostPosted: Wed Nov 13, 2002 12:01 pm
The Volare rearend is to wide for a '64 Valiant.
PostPosted: Wed Nov 13, 2002 12:55 pm
thanks, i was afraid of that. i have another option with a 75 duster that a friend has stilling in the woods. V8 car, it could have a 8 1/4 in it. either way, i will be getting the front end components off of it.
 Post subject: Rear End Swap
PostPosted: Wed Nov 13, 2002 3:32 pm
The 75 A-Body rear end will swap in.
If it's an 8 1/4 the drive shaft will have to be shortened.
Also use the parking brake cables off your 64.
