It is currently Tue Jun 02, 2026 11:44 am
 Post subject: Eileen and more YouTube
PostPosted: Sun Feb 24, 2008 10:28 am
A couple of videos for your enjoyment. I still need to make one of it running down the road or track. There is a turbo like sound that wasn't there before the headers where installed. We'll discuss that later.
http://www.youtube.com/watch?v=X-u6hkiFM8o (idle with some reving)
http://www.youtube.com/watch?v=PmrpoPXC05Q (a little in driveway/garage burnout)
I haven't install the A/C kicker, so I turned the idle down a bit. Maybe a little to much in this video. I normally drive with the A/C on all the time so its not high on the to do list.
PostPosted: Sun Feb 24, 2008 1:56 pm
looks like YouTube was down.
PostPosted: Sun Feb 24, 2008 3:16 pm
Sounds pretty mean, my friend.
PostPosted: Sun Feb 24, 2008 3:37 pm
Thats awesome
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sun Feb 24, 2008 7:20 pm
Any seat of the pant difference that you can tell?
PostPosted: Sun Feb 24, 2008 7:30 pm
nice. hat off to you for having stayed with eileen.
Juan Ignacio Caino
PostPosted: Sun Feb 24, 2008 7:33 pm
Cool!
PostPosted: Sun Feb 24, 2008 10:10 pm
man thats just sick to hear and watch!!
1976 Plymouth Feather Duster
2002 Dodge Dakota 4.7l v8
PostPosted: Wed Mar 26, 2008 9:16 pm
More video t come when YouTube is back up.
First run exhaust CAPPED (closed)
R/T .011
60' 1.931
330 5.948
1/8 9.375
MPH 71.38
1000 12.347
1/4 14.875
MPH 88.76
Second run was bad. Didn't get a good burnout and smoked the tires pretty close to the 60' mark. Unfortantaly my camera person was looking at the stars or something. :roll:
Third run exhaust UNCAPPED
R/T .074
60' 2.020
330 5.953
1/8 9.315
MPH 72.53
1000 12.244
1/4 14.743
MPH 89.81
http://tinyurl.com/2d32cv timeslips
I should have run a couple more times and changed my launch technic a few more times. I am pretty sure if I could get consitently in the 1.9 60' if I combine the best burnout and staging technics of the three runs.
Now for the interesting but scary stuff.
As some may know I am running a Gear Vendors Over/Underdrive and I am split shifting gears (sometimes). That another thing I need to figure out. Whats the best shift combination. (split all gears, just the 1-2 or just the 2-3 shift). Well during the first run at the end of the track in 2nd-over and turning 5900-6000 rpm, instead of shifting in to Drive I hit the button and drop the overdrive. :o :o This engine has a rev limiter chiped at 6000 rpm, but if you drop the overdrive the CAR will push the RPMs past the limiter. I was very well aware of this but somehow I got confused and cranked her up to 6950 rpm. (data logger showed this) Well it held together and made two more passes with no problems. On the way home, at idle or lite coasting cruise, I am hearing a noise from the engine. Sounded like a rattle and I was telling myself its just the cold air pipe moving around. Ofcourse I am giving thought to the almost 7000 rpms I turned today, which was really making me nervous now. I get home and pop the hood with it idleing and making the noise and grab the air pipe and its not the source of the noise. I get a little sick at this point and start moving my ears around the engine and hoping I hear many something from the valve cover area. Nope. I am think broken skirt and piston slap or something not nice. I decide to shut it off and jack it up to check the converter bolts. I don't really consider myself to be a very religous man, but I was praying that the bolts where loose as I rolled under with a large screwdriver. I don't know of a happier moment when I found them loose. :D :D :D :D :D :D :D :D :D
YouTube coming soon.
PostPosted: Thu Mar 27, 2008 5:15 am
Solid 14's in the quarter, good.
If you haven't done it yet, I would use some "blue" locktite on those bolts.
PostPosted: Thu Mar 27, 2008 6:42 am
I had used red Locktite, so I am not sure why they came loose.
http://www.youtube.com/watch?v=M0n6_tBYtFg
PostPosted: Thu Mar 27, 2008 7:24 am
Hey, 14s, that's great! Looks like 14.6 should be well within reach with good launch, and maybe better with some tuning. 1MPH difference in trap speed means you are probably not "on tune" as you heat up. Low/mid 14s should be tunable...
You might try just leaving the gear split/OD off for a pass and see how that does. No overrevving in top gear for sure at <90MPH.
Congrats!
PostPosted: Thu Mar 27, 2008 3:15 pm
Bren, Nice - Now your getting the torque to the ground and turning some nice #'s
And loose torque converter bolts can be a real hassle - isn't it amazing that all that power is transferred through just 4 small bolts??!!??
Good Work !
PostPosted: Thu Mar 27, 2008 3:43 pm
http://www.youtube.com/watch?v=6VieBa4UpaI
Here's a video of the cuda latter that night in the dark with the exhaust uncapped. Sound pretty mean doesn't it. :wink:
PostPosted: Thu Mar 27, 2008 7:20 pm
Cool vids. I misspoke above. Didn't notice you were uncapped for the 2nd run. Faster MPH uncapped probably means you are a bit rich, at least when capped up. What is total timing?
