It is currently Wed Nov 25, 2026 10:21 am
 Post subject: fuel filter
PostPosted: Thu Apr 03, 2008 5:44 am
hi, i just installed a rebuilt holley carb on my 73 valiant, and unfortunately the float bowl continues to leak, which is why i got it rebuilt to begin with. although i wonder if the rebuilder actually changed the float and needle, i should also look at a good quality fuel filter replacement. any suggestions?
thanks cshunley
cs hunley
PostPosted: Thu Apr 03, 2008 10:17 am
cshunley,
Maybe your float is a little high. Is it leaking out the overflow vent on the top after you shut it off and it heat soaks?
Send me your email and I will send you a picture of my setup and filter using SL6Dan's mod. I am using the big stainless filter Summit Racing sells.
I also have a Perma Cool fuel water separator that they carry, but is not installed yet... need a few days of good weather this weekend. :D
PostPosted: Thu Apr 03, 2008 4:18 pm
ted i would like to see those pitures to :!:
PostPosted: Thu Apr 03, 2008 8:17 pm
Terry,
Just sent you some pictures of the setup as of about 4 weeks ago when it wasn't snowing.
