It is currently Fri Oct 23, 2026 7:15 pm
PostPosted: Sun Nov 17, 2002 8:11 pm
I need some part numbers for a Slant 6 head with stock valves 1.60/1.30 valves. Anyone done this conversion? The guy at the machine shop doesnt wanna do the work so I guess I hav to.I need bowtie valve numbers, retainer numbers, keepers, seals and springs. Any help would be appreciated..
Pete :twisted:
 Post subject: hmmm
PostPosted: Mon Nov 18, 2002 6:16 am
The valve sizes you have listed are smaller than stock Slant valves (1.62/1.36). What are you trying to do? :?: If you want SB Chev valves, just order 1.72/1.50 valves from Summit for any (60s for example) 283 or 307 or 350. I got mine from JC Whitney and all it said in the catalog was the head sizes. They are about 0.1" longer than stock Slant valves and the stems are 11/32".
Hope this helps, :wink:
 Post subject: valves
PostPosted: Mon Nov 18, 2002 8:16 am
That's what I did, too. I used Manley SS Chevy valves, and cut them down to 1.75(int), and left the exh's alone.
'70 Cuda AAR
'74 Duster 360
'79 MagnumGT
'79 Chrysler 300
 Post subject: Valves
PostPosted: Mon Nov 18, 2002 12:02 pm
Cox Brothers have stainless valves in stock. The extended length lou spoke about will help with high lift cams. We also offer 11/32 bronze guides, teflon seals, springs, retainers, keepers, and anything else you will need to do the conversion. We offer the valves in many head diameters. Give us a call at 614-268-9920
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 18 guests
