It is currently Sun Jun 21, 2026 3:46 pm
 Post subject: Carb Question
PostPosted: Sat Apr 05, 2008 8:43 pm
I have a 1945 carb on my 225. There is a hose that come from the carb to under the air cleaner. When I disconnect the hose my car runs much smoother and my idle speeds up a little bit. Should this be happining?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sat Apr 05, 2008 8:48 pm
Your creating a vacuum leak. That hose runs the hot air valve in the snorkel first thing in the morning.
Your carb must be running pretty rich. I would adjust the float level per spec..
PostPosted: Sun Apr 06, 2008 4:49 am
Yep, you definitely need to find and fix the cause of your carb's maladjustment. Could be as simple as an improperly-set idle mixture (most likely, since the adjustment screw is right out in the open for anyone to play with), could be a float set too high or a float set to the proper level but soaked with gasoline (heavy)...how long since you went through this carb with a rebuild kit?
PostPosted: Sun Apr 06, 2008 9:32 am
I must have adjusted the float wrong. I did it a few months ago.
Ronnie
PostPosted: Sun Apr 06, 2008 12:02 pm
Here is the Holley 1945 operation and rebuild manual (pdf).
