It is currently Sun Oct 25, 2026 3:01 am
Which profile interests you the most??
.500 - .600 lift 104-108 cl 250 -265 dur. (@.050) 40%  40%  [ 6 ]
.600 - .700 lift 104-108 cl 250 -265 dur. (@.050) 27%  27%  [ 4 ]
.600 - .700 lift 108-112 cl 265 -280 dur. (@.050) 7%  7%  [ 1 ]
.500 - .600 lift 108-112 cl 265 -280 dur. (@.050) 0%  0%  [ 0 ]
less than you see here 27%  27%  [ 4 ]
more than you see here 0%  0%  [ 0 ]
Total votes: 15
 Post subject: Roller Cam Poll
PostPosted: Mon Nov 18, 2002 6:50 am
Sorry I am still learning how to use the new forum. I think i was posting as a guest instead of Sassy Six.
 Post subject: I'm curious...
PostPosted: Mon Nov 18, 2002 11:12 am
Is the reason you can only grind a narrow range of profiles due to (1) the idea that grinding through some hardening layer is involved, or (2) due to the geometry of the core blank? If it's (2), then why not make the core blank lobes bigger and allow more variations? I have no experience here, just trying to learn. :?:
I'm very excited about this project, BTW. That's really cool if you guys can get the gear ground on the cam (especially for the non-full-race crowd - like me). Modern technology for the Slant is where it's at, in my book.
Lou :D
 Post subject: lobe profiles
PostPosted: Mon Nov 18, 2002 11:46 am
The limitations are because of the hardening process. The cams are close ground to the blank size, then they get hardened and straightened. Because of the cores moving a little during hardening, they need to be trued up. This is done at the finish grind, removeing only enough material to straighten and meet finish specs. There is no way to have only one core for every grind. To make them even close to affordable the cores must have all manufacturing processes, except final grind, done at the same time.
 Post subject: thanks
PostPosted: Mon Nov 18, 2002 1:48 pm
Thanks mucho, Mr. Cox. That's what I thought from your 1st post, but wanted to make sure.
