It is currently Mon Nov 23, 2026 8:59 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Fri Mar 28, 2008 1:08 pm
thanks ill look it up.
71 dodge dart custom
1988 Honda Civic ((Because racecar))
2005 VW Jetta
1963 AMC Rambler American 440
PostPosted: Fri Mar 28, 2008 7:22 pm
http://tinyurl.com/yqcxox First picture
This first picture is of the ignition coil. Mine in red and if your follow the center spark plug wire from the distributor cap (the one you changed that new) to the coil, which is under the front most spark plug. Mine is kind of hidden by the coiled up hose and wire in this picture.
http://tinyurl.com/yqchye 2nd picture
The ballast resister. This part in at the top and 2/3rd to the right in this picture. I is right next to my washer fluid resivor in the corner of the engine bay. It is white and has two wire prongs on it. Your may have 4, as I didn't look what year your car is, but it will look alot like this one. Its made of ceramic.
PostPosted: Mon Apr 07, 2008 8:52 pm
are you guys sure its the ignition coil, those usually never break. Oh well ill just R&R it either way ((R&R is Remove and replace)) So R&R the Ballast resistor?
2005 VW Jetta
PostPosted: Mon Apr 07, 2008 9:15 pm
Ballast resistor FIRST,Then try it ,fast,easy ,cheap,mark
 Post subject: Do you...
PostPosted: Tue Apr 08, 2008 7:10 am
Has the timing chain been ever replaced on your car... if it's a bit loose it can also get kind of salty when things warm up (or if it still has the nylon cam gear and it's chipped a tooth....)
