It is currently Fri Nov 13, 2026 11:31 am
PostPosted: Sun Apr 06, 2008 4:48 pm
I know, I know...everyone yells at me when I talk about this, but I want to change my car from the pushbutton shift to a floor shift without having to yank out the tranny and replace it. Is this possible (has anyone here done it) and how much trouble is involved (try to convince me not to do it)?
Road Devils CC Nomads
1964 4-door Valiant
PostPosted: Sun Apr 06, 2008 6:09 pm
Build a bracket and mount the pushbutton mechanism on the floor. :)
PostPosted: Sun Apr 06, 2008 7:38 pm
Yep, that's about the only option on a PB setup.
PostPosted: Sun Apr 06, 2008 8:07 pm
Get a 65 factory cable floor shifter and the 65 valve body for the trans.
Personally I like the floor mounted PB setup better. Thats what I have in my 65 Valiant and 66 Cuda (used a 64 pushbutton assy, 64 valve body and a 65 trans).
PostPosted: Sun Apr 06, 2008 8:16 pm
I've never seen, considered of even thought about a console mounted pushbutton selector until just now, after seeing this thread.
It's about the coolest thing I've thought about lately; thanks for that!
1975 Duster 225, same thing in a van.
Also a bunch of Neons.
PostPosted: Mon Apr 07, 2008 12:31 pm
That does sound like a cool idea, but I don't want a center console. Just a floor shifter with a ridiculously big Ed Roth-style rod. I have a beer tap that would be a perfect shift knob.
1964 4-door Valiant
PostPosted: Mon Apr 07, 2008 1:31 pm
Have you looked a Lokar's aftermarket shifters? http://www.lokar.com/
Mainly used by the street rod guys but they are finding homes for their shifters in a few muscle cars lately.
Chris'
Autobody
Restoration
Service
PostPosted: Mon Apr 07, 2008 2:55 pm
i have heard that most aftermarket shifters won't work with a pre-linkage shifter. which is the main reason we're trying to do this trans swap (aside from the fact that the older trans needs to be rebuilt).. :(
PostPosted: Tue Apr 08, 2008 12:28 pm
lokar has a part number for a 32" automatic floor shifter for the 904. so would it work with mine or would i still have to swap out for a later year??
1964 4-door Valiant
PostPosted: Tue Apr 08, 2008 1:07 pm
Big ol' Rat Fink style shifter. I love it...
Gave me an idea for when I do my 4-spd conversion...
PostPosted: Tue Apr 08, 2008 10:41 pm
Yes sir. Gotta love it. But since the front seat is so close to the dash, it needs to be the single-bend one...otherwise you won't be able to put it in park. Which is what I believe is another problem. The PB just goes into neutral and the lever activates the lockout, so how would that work, if at all, with a floor shift?
1964 4-door Valiant
PostPosted: Wed Apr 09, 2008 7:30 am
It won't. As stated previously, the only options, if you use your existing transmission, is to use the 65 Valve body and the 65 cable floor shifter. You could then put a big "rat fink" handle on that.
PostPosted: Wed Apr 09, 2008 11:15 am
So I'd be better off just to get a 65 tranny that's already a floor shift and swap it out. Neat. Now the question is what to do with the buttons themselves and that panel...
1964 4-door Valiant
PostPosted: Wed Apr 09, 2008 11:47 am
You have to get the blank panel from a manual trans car and remove the existing bezel and shifter.
PostPosted: Wed Apr 09, 2008 1:26 pm
Still nope. 65 tranny is still a cable shifted trans, and used either a cable floor shift (one year only) or the cable operated columm shifter (again, one year only).
If you really want a floor shifter, you would, probably, be better off, getting a 66 or 67 trans (with converter), That will fit to your engine, then you can use an aftermarket floor shifter. You would have to change your driveshaft to the later style with the slip joint, and use a 1966 speedo cable.
