It is currently Mon Nov 23, 2026 6:37 pm
 Post subject: holley 450 cfm chokeless
PostPosted: Tue Apr 01, 2008 8:41 pm
Has anyone ever ran one of these on there slant?My friend gave me one to run on mine but I'm not sure about the chokeless part?Any input would be appreciated. Thanks
1984 d150 super 6
1979 aspen super 6
PostPosted: Tue Apr 01, 2008 8:47 pm
Is that the mechanical secondary carb that was so cheap the secondary side didn't even get an accelerator pump? The chokeless part will be a pain in cold weather starting, but the lack of secondary accelerator pump will likely be a pain every time you open the secondaries. I'll keep my electric choke vacuum secondary Holley 390.
 Post subject: Options...
PostPosted: Tue Apr 01, 2008 9:25 pm
Yep, or you can still order the Holley 1848, which is a 450 cfm 4160 carb if you need the extra little bit of flow... (I have one of these for the summer tuning on the Hpak duster since the 390 is a bit small for it, but 600 is too much, and I wanted to start fresh on dialing in a new carb and wanted to convert to a manual choke for winter driving...
PostPosted: Wed Apr 02, 2008 2:30 am
I took the choke off of my 4160 over a year ago. I drive it daily and have no cold starting problems, hit the gas turn the key and hold it at 1800 rpm for 1 1/2 - 2 min and drive off.
PostPosted: Sat Apr 05, 2008 8:06 pm
Thanks for all the info!! Shaker did you have to change the jets?
1984 d150 super 6
1979 aspen super 6
PostPosted: Tue Apr 08, 2008 4:20 pm
no just ran it stock.the jet size i believe is .058.it can be a little much if it is a stock motor but it still works good.it got me around town.
This account is used for member help ONLY!
