It is currently Sat Nov 14, 2026 12:40 am
PostPosted: Sun Apr 06, 2008 8:21 pm
The console mounted A/T shift linkage bushings are getting sloppy in the 67' Dart. Is there a supplier that carries a rebuild kit for these cars?
PostPosted: Sun Apr 06, 2008 10:17 pm
If they are the ones I'm thinking of, you may still be able to get them from the dealer.
PostPosted: Thu Apr 10, 2008 4:02 am
Yesterday I stopped into my local C D dealer to see if these bushings were still available. The parts counter guy dug out an old parts book, ran the part numbers, and no go. Sadly Walter P. dose not have these bushings at the present.
On the bright side, one of the younger counter guys is an "Old MOPAR" nut, he and his dad have a ton of A. B, E body parts sitting around left over from several rebuilds. He was going to check his pile for some good bushings.
PostPosted: Thu Apr 10, 2008 8:34 am
Are these them?
http://cgi.ebay.com/ebaymotors/Dodge-Ch ... QQtcZphoto
PostPosted: Fri Apr 11, 2008 6:04 am
IIRC, I saw on Moparts that there are still bushings available from Ma that will work, but are a different color or something silly like that. They are like the column shift linkage bushing from a late 80's Ram. :shock:
PostPosted: Sat Apr 12, 2008 2:41 pm
Slantzilla,
available from Ma
Could you translate Ma, or pass along a hot link for me to check?
PostPosted: Sun Apr 13, 2008 8:01 am
Slantzilla,
available from Ma
Ma=Ma Mopar=your dealer :shock:
PostPosted: Mon Apr 14, 2008 4:07 am
Thanks
