It is currently Sat Nov 21, 2026 6:04 am
PostPosted: Fri Apr 11, 2008 6:33 am
When I walk past my Dart, I get a really strong gasoline odor emenating from it.
It is most noticable when I have just shut the engine down after driving, but sometimes even the next morning it is there.
I replaced the rubber line at the fuel pump. Can't find any leaks around the fuel pump, lines, filter or carb. I can't find liquid gas anywhere under the hood.
The smell is very hard to pinpoint too. I've sniffed under the vapor canister, and other places too. It just seems to come from the engine bay somewhere ???
Anything else I can check? Anyone else ever have this issue?
Thanks guys,
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Fri Apr 11, 2008 6:44 am
Assuming the charcoal canister is hooked up correctly and in good condition, probably what's going on is fuel boils in the carb, spews into the intake manifold, vapourises there and then disperses as vapour, which you can smell. What is the status of the carburetor in this car? Rebuilt? New float, set correctly? Have you done the fuel line mod yet?
PostPosted: Fri Apr 11, 2008 7:20 am
Dan, the fuel line mod was next on my list.
Carb condition is unknown. The car appears to have 36K original on it. I am assuming carb is original and unmollested. But after 30+ years anything is possible.
Yeah that nasty steel fuel line runs right past the exhaust manifold.
According to the vac diagrams, the canister is hooked up correctly and I even replaced one of the lnes on it that was in bad shape, as well as several other vac hoses and pcv hose, and pcv valve.
Thanks for the suggestion. I'll post back on how it goes!
PostPosted: Fri Apr 11, 2008 3:15 pm
hello,
my money is on the gas tank.
to check it requires the tank to be dropped,but mud and road grime create rust on the top of the tank and pinholes develop. :(
eexactly what happened with my Aussie valiant A body.
:shock:
regards,Rod :D
PostPosted: Sat Apr 12, 2008 7:10 am
I would examine very carefully around the fuel bowl gasket and then give the throttle a couple of pumps and look for leaking fuel around the throttle shaft. Another possibility is that the fuel pump diaphragm has a leak. There is a small hole in the pump body where the leak would drain from the pump. You would not be able to see it except from under the car or if you removed the pump.
PostPosted: Mon Apr 21, 2008 3:44 pm
bump.
hey Chris,
did you get your gas smell fixed? if so,what was it?
regards,Rod :D
