It is currently Sun Nov 22, 2026 3:37 pm
 Post subject: New Header Flange
PostPosted: Fri Apr 11, 2008 7:28 pm
I wanted to share a header flange I got from www.millerscustomheaders.com
1/2" mild steel, water jet cut. Cuts are very clean, ports are large enough to allow for insertion of tubes, and seal welding from the gasket side.
$75 shipped to my door two days after ordering. Accepts paypal or normal money.
mh-
PostPosted: Fri Apr 11, 2008 8:20 pm
I have always been bugged about where you can find square stainless tubing for the exhaust ports. Have you found a good source for that?
PostPosted: Fri Apr 11, 2008 8:29 pm
Those are nice and all, but $75 seems a little steep. I wonder if they would do a group buy like Erson?
PostPosted: Fri Apr 11, 2008 10:21 pm
Matt, are you going to make a swedge so you can square up the end of some round tube to fit the flange?
PostPosted: Fri Apr 11, 2008 10:42 pm
Rick,
I'm building a turbo setup here with pipe and weld ells. I've done it before using the time honored heat, bash, squeeze, cut, weld and grind method. However, I have considered building a swedge to form short transitions as they exit the the flange prior to the bends. I would have to use a press and some heat, but it should be easier in the long run.
Joshie,
Yea, $75 may be a little steep but they had them, and I have been intending to make my own for too long, and haven't. This catalyses the project to a degree. Clifford used to sell uglier ones for $50, but don't any longer. A few years ago I was getting some other parts cut at my waterjet guy, and he quoted $40 each, if I would wait untill he had suitable scrap. Didnt bother getting a real quote as I wasnt interested at the time. Steel costs are roughly 30% higher now, not to mention other inflation. Whatever, I have a new parts to weld on...!
PostPosted: Fri Apr 11, 2008 11:40 pm
Those are nice, and yes metal has gone up a lot lately. WIth a 1/2 flang that is a lot of metal and they should hold up nice for a turbo build.
I would suggest a strap between the two flanges after the header is built so they dont seperate from the heat and make a reinstall give problem.
Jess
PostPosted: Sun Apr 13, 2008 6:22 pm
Hey Matt,
Nice parts, dude. Good to see you are back on the Valiant project. Been driving that 5spd beast around much? Keep us updated on your diabolical plans...
Cheers,
