It is currently Fri Nov 13, 2026 3:12 am
PostPosted: Sat Apr 12, 2008 11:50 am
Hi all,
The axle bearings stick out of my axle a small amount ( approx 1/8th of an inch). I measured the inside depth of the axle, and it appears to be made to do this.
Two questions:
1. How much do your axle bearings stick out?
2. is this normal?
It seems like bad engineering to me.
PostPosted: Sun Apr 13, 2008 6:29 pm
Greg,
If you have a disc kit and eliminated the drum backing plates, they will stick out, yes. I took my old backing plates and cut the centers out to use as spacers, reused the steel shim orig gaskets, and some permatex. I would not leave them open like that, but they are a sealed bearing so maybe it's OK.
PostPosted: Sun Apr 13, 2008 8:30 pm
Thanks Lou.
I used some crummy chinese bearings, and they stuck WAAYYY out there. I took them back to the machine shop, they charged me an arm and a leg for FM bearings ( and total redo on labor), and they seem to be better now.
I am not going back to them for the engine work on my new engine. They gave me a bunch of crap for not getting the bearings from them the first time.
