It is currently Sat Nov 21, 2026 12:00 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page 1 2 3 Next
 Post subject: Slant in a bigger rig
PostPosted: Mon Apr 14, 2008 12:49 pm
Hi all, I have a late 70s Dodge chassis class C mini motorhome, currently low compression 400/great 727/4.11 dually and 7mpg. A real pig. It's a 19-foot, not huge, and I'm thinking a slant six built for torque, a beefed 904, and maybe a gear vendors unit would give me ok power, adequate highway speeds and decent (maybe 15 at 55?) mileage. Am I dreaming?
The whole thing's getting torn apart, it'll lose some weight, and I want to build it to drive for the next 20 years. I'll sacrifice some performance for durability... I have a '67 slant six and 904 coming out of a valiant project car. What do you all think?
Thanks so much, been a lurker here for the last year... great board!
~Scott
62 Plymouth Valiant "Alvin" 170
74 Dodge D100 "Joe" soon to be 225
74 Roadrunner "Sarge" 360
PostPosted: Mon Apr 14, 2008 1:01 pm
Just my opinion, but I'll bet it would take you a very long time to get $$ return on the cost of the 904 rebuild + Gear Vendors overdrive (in fuel savings).
The 400s did have a reputation for having relatively poor performance (don't flame me, folks... just what I remember from the '70s).
My thought is that you would be happier rebuilding the 400 with an eye towards an compression and an "RV" spec camshaft and perhaps a dual-plane intake and headers. Parts are widely available.
The Cortez motorhomes came with a Slant Six. Perhaps someone on the board that has driven one can speak to performance and economy.
-Mac
PostPosted: Mon Apr 14, 2008 1:12 pm
From where I sit a 318 is the smallest thing I would put in a vehicle with that kind of frontal area (big time aero drag). If you never want to climb hills you could probably get away with the 225 and 4.10 gears, but I don't see an overdrive working out. The 225 just won't make enough torque to take advantage of the overdrive. Splitting gears would be helpful though. If it were my motorhome and the current engine is reasonably sound I would leave the 400 where it is, but swap on some older closed chamber heads to get some more compression, rework the distributor advance curve and make sure the carburetor was in top shape and tune. Headers with good exhaust would help too, but if you do headers do it before tuning the ignition and carburetor.
PostPosted: Mon Apr 14, 2008 1:18 pm
You won't gain any mileage if the small engine is constantly in the carbs power circuit (running rich) to keep you moving.............
Most likely, you'll get worse mileage.
PostPosted: Mon Apr 14, 2008 1:49 pm
Car Model: 1974 W100; 72 Dart
Lots of ways to make a 400 make power and improve MPG. Build compression by either milling or put in .040 over 440 pistons into a stock bore. Do all the things you can do to max efficiency....ie recurve distributor, A/F sensor to tune out the air ratio/jet the carb right, and get the engine to run in its torque peak.
With some careful tuning you might get into the low teens.
If doing a slant, all the above applies, but seems to me it would be tough on the highway. Get the thing going and it would be ok, but hill climbs and wind will be tough.
sb
PostPosted: Mon Apr 14, 2008 2:47 pm
A slant would be a real dog in this setup and would eat gas because it would be working its guts out.
If you really want to do something what I would suggest will take some money but it will improve MPG, power and durability.
The 400 is a great block to start with but they are way to low on compression to get any fuel mileage. Believe it or not I would get one of those 440Source stroker kits to put in it. A set of alluminum heads ( dont scream yet) that they sale is only around $800.00 and will help a lot also. THis will allow you to run the compression up to around 11.0 to 1 on pump fuel and will help fuel mileage a hugh amount.
Doing the 470 kit wiht the -4 flat tops would give you around a 10.20 compression with a iron heads. This will work good and can be done alot cheaper than you would think. Put the aluminum heads on top of this and you can push the comp up higher and still run pump fuel. The extra CID of the stroker kit and the higher compression will give so much more power it will be a joke compaired to what you are running. This allows the engine to not work near as hard and the tighter combustion chamber will use less fuel and be much more efficaint.
Also a set of headers is a must for your setup and with a engine built as described above and the headers the under hood temps will drop a hugh amount and water temp problems that are so common on these setups will be gone. The durability of a engine like this will be much better than the stock 400 and it will totally change your motorhome for the better.
This may seem like a bit much for a motor home but we have been down this road and its the only way I would even run one of these old motorhomes. It a night & day differnence in every way.
Jess
PostPosted: Mon Apr 14, 2008 2:55 pm
Thanks so far for the thoughts - more are welcome to chime in too.
I'm not so much looking to recoup, just have a vehicle that's less of a pig. I'll be building it for the next couple of years, and I'm willing to spend in chunks now what'll work for me then in ease of maintenance, reliability, simplicity and lower fuel costs. The math doesn't have to add up - just the fitting of my needs.
My other option (the big block is GOING) would be a 318. But honestly, though a little small, the thought of a slant six - the pinnacle of reliable service - under my engine cover, lights me up to no end. Too bad they didn't make a 300 like those other guys...
Yeah, never thought about it being into both bbls of the carb all the time... but seriously, if it worked even decently, how much gas can you possibly burn with 225 cubic inches?
~Scott
 Post subject: Plenty...
PostPosted: Mon Apr 14, 2008 3:25 pm
an over worked/underpowered/ undersized engine that's constantly in the power valve/ enrichment section to keep running would get you about the same as your current engine (remember the 'power/torque band' in the slant is going to be at a higher rpm than the big block....)...
I think reworking the 400 with a little more compression, an RV cam, and having a vacc. secondary carb that's a spreadbore with a way to adjust the secondary 'cut in' would help greatly (even if you use a Holley 4165, and changing out the power valve for the partial enrichment dual stage power valves would be a good investment...)...
my 2 cents,
PostPosted: Mon Apr 14, 2008 4:26 pm
Do you have any GVW estimate? (Gross Vehicle Weight)
PostPosted: Mon Apr 14, 2008 6:11 pm
Consider also that rebuilding the 400 into a torque monster (higher compression, RV cam) may allow you to run lower (numerically) gears in the rear end.
Cutting that rear end ratio down would make a significant difference in your engine rpm... and probably your mpg.
Do you suppose that this RV was designed with the current gearing to be optimum at 55 MPH (the national speed limit at that time) and that by driving it at today's speeds (65-75) you are killing the mpg?
PostPosted: Mon Apr 14, 2008 6:12 pm
Keep the 400, bump the compression, freshen the heads and put a late model lockup trans in it and go.
PostPosted: Mon Apr 14, 2008 8:45 pm
I have a 1966 Clark Cortez motorhome, which is an 18.5' all steel "class A" coach powered by a /6. Most Cortez owners complain that it is underpowered. Many owners have converted to a 318 V8. The Cortez weighs about 12k pounds when loaded. With the /6 in it's stock form, the Cortez travels at highway speeds just fine on flat ground; but going uphill will reduce you to about 35mph. I usually get about 14mpg.
I would never convert from the slant six in my Cortez, but to a good extent because it adds to the uniqueness of the coach. But I am willing to settle sometimes for taking things slow.
A stock 318 has about 200hp, you can build a slant to get about the same power and still be reliable. I'm in the process of rebuilding mine for performance, we'll see how it moves then.
Good Luck!
-Moose
1966 Clark Cortez, Industrial /6
PostPosted: Tue Apr 15, 2008 4:51 am
Installing a turbo would be a good way to aproach your Clark setup. I am surprized that you can even get 14 mpg out of it, if it can do 14 mpg then a good build with a turbo will give pretty good results. EFI turbo would be real nice, but the right carb would work just as good.
Jess
PostPosted: Tue Apr 15, 2008 5:11 am
Keep the 400 get some 516 heads, put in hardened seats. They are closed chamber, polish the chamber, small Aluminum after market heads flow to much for an engine that needs low to mid. People give away the 516's. Do an RV porting job.
A Thermoquad would work great on a stock intake. A stock 440 crank would be nice to jump the cubes with the right pistons etc, cut down the main journals. Can find them for $125 or so.
What's your budget?
If you look hard you can find a TQ Offy Dual Port for $50-75. It is a torquey intake. I run one on my 6000lb van with a 360.
Put a tach on it and build for that RPM range.
PostPosted: Tue Apr 15, 2008 2:47 pm
My uncle had one in his 40' troller. Great little engine! We went plenty fast and never had any problems.
Another friend has one in his motor home. Got 15 mpg with the one barrel,
16 with the two barrel and about 15 mph faster on the hills.
Next, He is planning on trying a 4 barrel like came on early Chevy 283's.
Users browsing this forum: Ahrefs [Bot] and 5 guests
