It is currently Sat Nov 21, 2026 9:29 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Apr 16, 2008 12:55 am
If you insist on an automatic move up to something newer such as an A500 or A518. In a vehicle of that weight the locking torque converter is as important as the overdrive.
Unless your up to building an EFI turbo slant I would go with a 360 or 5.9 magnum it would bolt right up to the overdrive tranny and if built right would be powerful enough to stay out of the power enrich mode in the carb a good deal of the time.
1970 Vitamin C Duster 225 2bbl 904 eventually turbo efi r154 5 speed
1969 B5 blue roadrunner 383/727 soon to be turbo slant (JK)
1972 Barracuda was green 318 who knows?
PostPosted: Wed Apr 16, 2008 12:21 pm
I suppose tweaking the engine you have is almost always better than swapping, at least from a cost perspective. Time=Money and I have neverseen an engine swap that didn't require both.
Now, having said that--a Slanted motorhome could be done. I have seen plently of four cylinder Toyota's doing duty as a Class C. See the website below:
http://www.toyotamotorhomes.com/product_reviews.htm
What I have noticed when it comes to RVing is that if you can get over 15 mpg you should celebrate. I rented a V-10 E-250 chassis 24 foot RV and drove 800 miles with it. It got 14 mpg on the flat, maybe 10 mpg in the hills. Torque? Plenty. EFI? Yep, had it. State of the art and mileage was still bad--or maybe not. Afterall, short of nuclear power you are not going to have an easy time shoving a shoebox through space.
FYI, my PAW catlog shows Edelbrock aluminum heads for ~$800 a piece for a 400. Looks to me like you will be ahead by just giving some love to what you have. I think we often forget what our engines were like when they were new--generally speaking getting them back to like new condition should put a smile on your face..
Slanted D150
PostPosted: Wed Apr 16, 2008 2:54 pm
Why aluminum heads that work at high RPMs? :roll: Would make a slug out of it, no low end torque etc.
Better off with the 452's it already has or build the closed chamber, 516's, with the smaller ports for more VELOCITY. Closed chambers=detonation resistance, more compression etc.
PostPosted: Fri Apr 18, 2008 5:47 am
Again, thanks for the opinions very much. Vehicle weight should be around 8-9000 lbs. Yes on the automatic; I like the thought of an overdrive automatic with lockup. Will these later transmissions work in a non-computer vehicle (not complicating the vehicle any more than I have to) and (hypothetically) bolt to a /6?
On the engine - what about building the six for torque & midrange? (Humor me & help me really think this through)... I'd give the engine the benefit of the doubt, electric fans, no AC compressor, etc.
My father had a Toyota-based motorhome, 4.33s & 55mph if I remember, but 4-speed. The power wasn't nearly as bad as the overstressed chassis.
The poor mileage I got in the limited time I drove this beast of mine WAS at 50-55mph. I didn't do much interstate driving.
My budget spread over the next couple of years will be 4-5000 or so, and it will be a learning experience for me. I'll be building with aerodynamics in mind; air dam, lowered, no flat faces into the wind, lower profile.
Again, thanks & I value every opinion.
~Scott
62 Plymouth Valiant "Alvin" 170
74 Dodge D100 "Joe" soon to be 225
74 Roadrunner "Sarge" 360
PostPosted: Fri Apr 18, 2008 7:43 am
Hi Scott. It's obvious to me, as a /6 motorhome owner, that the slant can do the job. With the right carb, cam etc., it would move your 8k-9k fine (mine was fine with a worn-out stock engine at 12k lbs). I should point out, though, that mine has a 4speed manual transaxle. You will definately have noticeably less power on the hills than with your current engine, you might even be disappointed.
I think the guys are trying to point out the obvious. Why would you want to give up so much power, when MPG gain with a /6 compared to a properly built and tuned V8 may not even be present?
I'm hoping to have my build complete in the next two months. I've bought everything to put it together, just need to get started now. I'll post the results here when complete. Here are the basics of my build:
- original 1966 225 bored .060 over
- 1972 Cyl head with oversized valves, some unshrouding work and bowl blending.
- MP244 Cam
- Weber 38DGES Carb on offy manifold
- Dutra Dual exhaust (modified rear manifold)
- New Rollmaster Double roller timing chain
- Teflon crank scraper
- Electric fan
Good Luck,
-Moose
1966 Clark Cortez, Industrial /6
PostPosted: Fri Apr 18, 2008 10:26 am
I agree with the build info. listed above and would add oiling system improvements. (oversize & deburred passageways w/ a "blueprinted" oil pump)
I would use the RDP Erson cam we worked-out with them during the group buy, it is just a pinch more aggressive then the MP244 but still has a bunch of low & mid range power and a smooth idle.
Big displacement also helps, a 4.44 stroke crank combined with a 3.48 - 3.5ish bore would really give the engine some additional "grunt".
I currently have this combination in my 66 Dart station wagon and we use that car to flat tow my 2700 lb racecar all over the West.
Combined vehicle weight is a pinch over 6K and that 4.5 stroke, 260 CID SL6 engine will pull a steep grade (like the I-15 "Baker grade") in drive with 3.07 gearing at 2700 RPM (3.23 work a little better)
PostPosted: Fri Apr 18, 2008 10:42 am
Because I think carefully approached there is definite mileage gain to be had with the 6 under cruise conditions, it's a whole lot easier to work on, a ton more durable, simpler to maintain, and I just like the concept. Try changing the plugs on a big-block van... and honestly a late 60s 318 would outpull a late 70s 400. Even stressed low, I'm not convinced a thin-wall 400 will last like a slant 6 even though the 6 will be worked harder. I'm not going to tow, I have no need to cruise at 80mph... but I would like to have enough suds to keep it pulling up a grade in third with 4.11s. If that won't happen with a six no matter what... ???
I think more gears is the answer, as brought up by the guys... definitely transmission rather than external overdrive. Just wonder about the adaptability.
I'll be very curious to hear of your results, being an actual "six in a big vehicle" owner. Do you have a site or page up about your MH?
I've heard turbocharging is the great answer on a slant, but that's WAY more engineering than I want to get into. And you know, if the slant didn't work out in the MH I could then drop in the 318 and find a '66 Valiant for the six.
Again, thanks to all... all the suggestions & info are of great help.
~Scott
 Post subject: Yep...but...
PostPosted: Fri Apr 18, 2008 11:27 am
Well... :roll: ... take your 400...plane the heads to work with leaded regular (not wheezy 8.2:1 compression ... put it back in the 9.2:1 compression range)... pull the smog system off it, and rework the 'lazy distributor curve' (yeah I have a couple of these distributors... set to TDC, 34 degrees of mechanical advance and a long throw vacc. advance... to get that flame all the way across the bore about 50-60 degrees adhead of time) and the 400 will do just as well as the old 383 (in fact if going 'overboard' you could always read AndyF's 451 manfesto- the 400 with a 440 crank scenario)... or either way take the 1968 LA 318 and add the late 70's smog heads, put the EGR and 1979 distributor in it and see what happens...
good luck on your mission, you've got your mind pade up... so does the K-frame use truck motor mounts for easy swapping? Got the slant truck A-727 prepped?
PostPosted: Fri Apr 18, 2008 1:27 pm
Yeah, I think I'm going to have to at least try the six. I have no idea about any mount issues - that's next! Just trying to get a game plan. Cursory glance looks like it's more mounts than any kind of K frame. If I'm wrong, I get to learn more! :)
The six is out of a '67 valiant; no six-powered trucks (yet). My little fleet will be running this year (except the motorhome), all 318-powered. This'll be my first engine rebuild...
Thanks for the info, head numbers etc. Believe me, it's ALL getting filed away safely and I'm not ruling anything out. Life so far has been following instincts, and I've got one that this is going to work with the right parts in a minimalist, reasonably aerodynamic rig.
The drivetrain is the first thing I'll be doing once it's back down to a cab & chassis. So ok... let's say I'm going to try the six. Carb recommendations? No FI, please. 1, 2 or 4 barrels?
Thanks for putting up with my lunacy & sharing your opinions & info.
~Scott
PostPosted: Fri Apr 18, 2008 2:08 pm
Car Model: 1974 W100; 72 Dart
hey;
want to give away your 400? I'm looking to build a race car with my dad this summer.
sb
PostPosted: Fri Apr 18, 2008 6:45 pm
Car Model: 1964 Dodge Polara 2 Dr HT /6 3spd man
It really depends on your driving and wants. If you drive like a grandpa (like me) it might work out fine. The 225 was used in trucks as large as the D500 and W500 (17,000 lb plus). They used NP435 4 speed transmissions. Also cool 2 speed rears. ???
If not and you got the cash I'd go with a diesel swap instead of the 400ci. you could yield about 30mpg with a 4bt! I don't think you'll get the 400ci to a point where it'll get good enough mileage. Just an opinion.
Dale
1964 Dodge Polara 2dr HT /6 3spd man.
PostPosted: Fri Apr 18, 2008 7:36 pm
I had, or rather have a Southwind with a 440. It pretty much always managed 9 to 10 mpg. As a guess I'd say that your mileage isn't going to change much from the largest to smallest engine you could put in there.
That reminds me. One of these days I need to get the 440 4 barrel out of the motorhome. It's runs great, but the body of the motorhome is pretty mich shot. Over the years, water damage has pretty much ruined the wooden frame box.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Fri Apr 18, 2008 8:18 pm
Thank you!
If you build the 400 right it just might skunk a slant on MPG's.
PostPosted: Fri Apr 18, 2008 11:25 pm
For the money to get a good powerful slant to pull this along you might as well find a wrecked 88-93 dodge 3/4 ton diesel and Swap everything over. A diesel motorhome could get a good 20 mpg and you would keep the motor in good shape. Diesels need to haul things on a regular basis to keep the engine clean and efficient. Like the 1.9L diesel VW's they pull around a "heavy" weight that keeps the engine clean. Which is why most of the cummins diesels you see in the million mile club constantly are hauling trailers or campers, etc. Which is why the weight from your motorhome would make a diesel a perfect choice because of the fact it's always hauling a weight.
PostPosted: Sun Apr 20, 2008 10:58 am
with a slant in it.
http://sanantonio.craigslist.org/grd/633544502.html
sb
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 5 guests
