It is currently Sat Nov 21, 2026 11:47 am
PostPosted: Sun Apr 13, 2008 8:22 pm
Yeah, me too, the thermal coated set so they will last..........add nice long collectors and a "X" pipe for some good low end torque. I want all my torque at 2000 rpm to pull even harder so I can run taller tires.
PostPosted: Fri Apr 18, 2008 1:33 pm
Lord, those are pretty!
Yeah, pretty expensive! Look at the price for the ceramic coated one. YIKES!
PostPosted: Fri Apr 18, 2008 1:44 pm
You guys realize you just sent the original poster toward a set of headers that wont fit his car?
PostPosted: Fri Apr 18, 2008 2:21 pm
Seeing that most SL6 headers never seem to fit in the chassis with-out hitting something.... I would never buy the headers already coated.
I would first do a fit check, move pipe(s) around as needed for a good fit, then send the headers out for coating.
I also take the time to do a careful fit check with my "Dutra" cast iron dual exhaust manifolds prior to having them coated.
PostPosted: Fri Apr 18, 2008 2:33 pm
Car Model: 1974 W100; 72 Dart
Hooker/Summit claims 62 - 72, which doesn't make much sense to me. Maybe they changed them somehow?
sb
PostPosted: Fri Apr 18, 2008 3:41 pm
Not me, I endorsed nothing :P
PostPosted: Fri Apr 18, 2008 11:38 pm
How would one come across a set of "Durta" cast manifolds? Is the only way by making them yourself? If any one had a set they would like to sell please let me know.
All in a days work
PostPosted: Fri Apr 18, 2008 11:54 pm
PM Doc he might have some still.
PostPosted: Sat Apr 19, 2008 10:59 am
Sandy,
Have you tried them?
What is the story?
PostPosted: Sun Apr 20, 2008 6:40 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
hi guys, mine name is Jason. ihave a 64 dart 225 /6. picked it up for a good deal. redid the interior,lowered it,and some wheels and tires and absolutly love the thing. I went throught it adjusted the valves, new points,cap,rotor,wires,plugs and rebiult the carb and the thing runs great. Also went throught and fixed all the oil leaks. I have put alot of miles on it and cant belive how good it runs. now the question i have for you guys I want performance. With a super six set up would i feel a difference? or would i be better off with the clifford (or like) intake and header setup. I am pretty sure i will add a cam pretty soon as well if you guys recommend it.If i could get your guys opinion that sure would help Thanks in advance, love the website
Another recomendation to add to the list...Get rid of the points and go electronic! it's night and day!!
