It is currently Sat Nov 21, 2026 12:20 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Apr 20, 2008 11:49 am
Interesting, interesting. Diesel... if I had more wrench time under my belt I'd like the sound of that whole drivetrain swap... but that's out of my league.
Had a van with a slant six (I know, much lighter) and it'd get 18-20... I can safely say a 400 wouldn't do that. I know weight & drag will nullify some of that as the six works harder... but I doubt all of it.
Remember, this isn't a huge class A - it's a 1-ton van with a dually rear, a little more drag (wider, taller), and about 2500 pounds over the average 3/4 ton work van. The overcab bunk is going during the rebody. Half the MH stuff will be gone. No genset, roof AC, black water or propane tanks... when done it'll be more in the TransVan family. It's only 19'... I sure wouldn't be thinking of it in place of a 440 in a Southwind. :D
But I bet that engine in just its stock low compression form would make an A-body flat fly for short cash.
As for my 400/727, no, not giving it away... have to fund the projects with the extra parts! But I'll entertain offers, especially if you & a few want to come shoehorn this thing out of it! It's wall to wall valve covers.
I've seen 'em come out the front (nuts on a Dodge) and out through the passenger side (like playing "Butterfingers" but very smooth - tranny out under, engine out the door!)...
Honestly I think I'll hang onto the 400 for now until I'm done needing to move the vehicle around.
Ok, so let's say I'm trying the six. Would love to stroke it but that's out of my league right now. But .060 over, .060 off, cam, aluminum intake, carb & headers... this is as much an experiment in what can be done with nuts & bolts readily available and very little re-engineering. Your experiences in a great slant 6 torque/midrange combo? Results? Links to other threads? How's that Clifford head?
~Scott
62 Plymouth Valiant "Alvin" 170
74 Dodge D100 "Joe" soon to be 225
74 Roadrunner "Sarge" 360
PostPosted: Sun Apr 20, 2008 7:15 pm
If you're going to cut the motorhome down so much and want economy you should save your self a couple hundred hours labor and go buy a VW Westfalia. My Dad's 1.9 water boxer Westfalia got about 19-22 MPG.
PostPosted: Mon Apr 21, 2008 2:04 am
Car Model: 1964 Dodge Polara 2 Dr HT /6 3spd man
I looked into the VW's before. The diesels are rare and expenisve the non-diesels, well hell you might as well back pack it. The slant six will give you a lot more get up and go in your set up. I think you can yield good mpg's with the right set up. If mpg's is your true concern, for the price of West Falia you could have somebody install a Cummins 4bt. You'd get 30 mpg with some real power. Dale
1964 Dodge Polara 2dr HT /6 3spd man.
PostPosted: Mon Apr 21, 2008 7:10 am
I think you should pass on thinking a diesel swap in that RV. I believe you said your budget was <$4K--a diesel will eat that fast! I "dropped" a 200TDI into my 1965 Series IIA 109" Land Rover, mostly a straight forward swap (if there is such a thing). I spent thousands for the motor and much more to make it look good and operate well. Diesel engines are built tough and cost accordingly.
If you don't want to hang with the 400 I imagine that you can follow Dutra's articles on building a stroked slant--that sounds like a spunky motor. I asked around my local machine shops and they were not terribly keen on doing the crank work that DD described--to be fair they said that they COULD do it, just that I wouldn't like the price. Probably time to take a class at the local vo-tech again--machine tools and a skilled machinist all for the price of the class, pretty good deal... The machine shops said the farther you got from stock rebuild the more they actually had to think and pay attention, lol...apparently that costs more :)
Anyway, I would have to think that a the following applies:
1. No replacement for displacement. The 400 CID can be made to perform and it should be cheaper than any engine swap.
2. The Slant Six is inexpensive (compared to a diesel)--they folks on this board know how to make the Slant Six perform and it might work out in that RV. Just seems like a bunch of work to me compared to breathing some life into what you have.
3. Diesels have torque aplenty, but they cost big $$. It used to be that diesel was less $$ than gasoline, not so anymore. Normally a diesel gets good mileage (better than gasoline motors in exactly the same application) but I wonder in the RV. Seems to me the choices for mileage in an RV are bad, and mo' bad.
However, having babbled on I do think it is cool idea--I like oddball motors and the Slant fits that bill. If you really wanted to "get er done" you could just stamp a bowtie on your forehead and drop a Chevy 350 drive train in and be done for under that $4k mark...but where is the fun in that!
Slanted D150
PostPosted: Mon Apr 21, 2008 6:23 pm
If he wanted to drop in a 350 (like every other conformist in the Chevy kingdom) he probably wouldn't be on this sight. I'd pick a 360 over the 350 anyday! Also you are right about the expense of diesel though I'd recommend the 4bt over the Land Rover engine. The point I was making was $ vs. the recommended VW which in descent shape can go around $10k plus. I believe you're way off underestimating the power of the Cummins (it's not the same as your de-tuned 200tdi). It has enough power stock and is capable of extremely big numbers with relatively little add ons. The gas mileage it can deliver would make it a good fit for this rig. Frito-Lay, Fe-Ex, UPS, etc... opt for this engine as well. If it was just power that was sought for the 6bt would be the recommendation.
PostPosted: Mon Apr 21, 2008 6:35 pm
A VW?... I'm ready to work on this thing, but to get it built. Not all the time for the rest of my life. Chevy 350... I'd bolt in a 318 first. I'm a Mopar guy, and have 4 other cars with 318s. That'll be my fallback plan. :) Diesel... out of my $$$ league guys, I build guitars for a living. If I were a diesel mechanic and great welder myself, I'd be all over it, turbodiesel city. But I'm not and that's out of the question.
The 400... too much. Before long gas'll be $5 and I can't justify putting a dime into something that big & heavy with holes that big. Does not, will not meet my requirements & needs in this vehicle. In a short van with portholes & side pipes? Maybe. In a '78 Volare wagon with cop suspension and a 4-speed? Definitely. But in something I'll need to feed & work on out on the road, a thousand miles from home? Hell no. Give me a straight six. My needs: simplicity, ease of maintenance, economy, durability, power. In that order.
I'll try the slant & let everyone know when I start the build. Meanwhile, I'm going to post on the tranny board about later-model 4-speed auto tranny adaptability. Just gathering info right now so I can start chasing parts. If it goes in & climbs ok & gets 15mpg, I swear I'm coming to stay over in all of y'alls driveways to collect cold O'Douls Ambers from each one of you. :D :D :D
Seriously I do thank you all and this is a fantastic forum.
~Scott
PostPosted: Tue Apr 22, 2008 6:54 am
Way to go, great choice! Looking forward to future posts of your build.
Dale
PostPosted: Tue Apr 22, 2008 7:47 am
A stock 2 barrel poly 318 (w) 727 is a sure way to go. They are rated at 200 hp stock. Add a four barrel and Norms DTA Headers and you still can burn regular and produce major torque with about 275 hp. Probably more. I have had several polys and they are a better touque and hp engine than the later LA 318 engine.
Geared with 4:10's you will get 14 mpg at 60 mph. You will need a carb that flows about 500 to 525 cfm. True story, and way under budget. ! ! See Norms Poly 318 Headers at,
http://www.t137.com/dtapoly/addpoly.php g/6
