It is currently Sat Nov 21, 2026 7:24 am
PostPosted: Mon Jul 09, 2007 9:16 pm
I know this seems like a ridiculous question, but bear with me.
My '66 225 slant had some cylinder head bolts that were not doing so well, so I finally ordered the ARP replacements (couldnt find another set elsewhere)
Well they sent me a stud kit, but the old ones were bolts. How do I install and torque the studs so that I can install and torque my head? The directions that were sent with the studs said I was only to tighten the studs "hand tight", but that seems odd to me. If they are in fact installed "hand tight" will the torquing of the nuts after the head is on carry over to the studs as well? I would check the manual, but the manual refers only to factory equipment, which means bolts and not studs.
help please.
Caesar
PostPosted: Mon Jul 09, 2007 9:45 pm
The instructions are correct. Make sure the holes in the head are very clean, chased out with a tap, and use a good sealer. When you torque down the nuts, everything will be tight. Be sure to use the specs they provide including what lube to put on the top of the studs and bottom of the nuts.
PostPosted: Mon Jul 09, 2007 10:35 pm
Check to be sure there is a good size chamfer (counter sink) at the top of each threaded hole, the area around the treaded hole tends to get pulled-up.
PostPosted: Tue Jul 10, 2007 4:24 pm
Pretty much what Anothersix said. I use a good high temp thread sealer (red Permatex, or better yet, Loctite 592, which is the high temp stuff). Make sure the holes are properly cleaned out with a THREAD CHASER and not a tap. The sharp edges of a tap will introduce metal shavings and can damage the threads, resulting in a poor fit for the studs.
How I install studs is I put two nuts on the portion that'll be outside of where you're installing it, snug them together with a couple wrenches, smear a small amount of thread sealer on the threads, install them by hand (into the block, in this case), and then use a wrench on the top nut to snug them down just a bit. Then to remove the nuts just turn them apart with two wrenches and spin them off by hand. Allow time for the thread sealer to set up (hell, if you can afford the time, let it cure completely), then install the head.
PostPosted: Tue Jul 10, 2007 11:09 pm
Here is a simple tool that makes stud installation quick and easy.
Take a proper thread nut and weld a smaller nut or flat washer to one end, so it ends up with a "hard stop".
You screw the "stud driver" onto the top of the stud and screw the assembly in. With a little practice, you can bottom-out the stud and "snap back" on the wrench to unscrew the driver nut.
PostPosted: Wed Jul 11, 2007 10:03 am
the ARP studs have an Allen head on them you can use to spin 'em down.
PostPosted: Wed Jul 11, 2007 9:01 pm
everything went well (as you can see). The cylinder head studs went in perfectly as did the intake/exhaust studs. The engine is really coming along and we have a lot of momentum behind us, things are really moving fast now.
I just have to set the timing and then the timing cover will go on, and then I can bolt down the valve covers (after I set the lash of course).
Cleanliness is key, with everything. I will show a before picture so you have an idea of what it was before the tranformation.
Projected Fire up date is 07-22-07.
wish me luck, and thanks for all the help (more questions will be coming in the future, I guaruntee it).
Image pulling the filthy tired animal.
Image studs IN with high temp loctite.
Image nuts torqued and head installed (finally)
Image done for the day.
Image same side of engine as the "before picture" with my dad manning the block out of the bay.[/img]
PostPosted: Thu Jul 12, 2007 6:19 am
my ARP set came with allen wrench socket on the top end...
Juan Ignacio Caino
PostPosted: Mon Apr 21, 2008 9:23 am
Where can I get a set of intake and exhaust nuts, washers and studs?
I used to see a set on ebay but no more.
Jim
Jim
Moon Lite Vans Inc.
PennsylVANia Van Council
PostPosted: Mon Apr 21, 2008 10:11 am
WOW, that is a nice, clean, good looking engine. I'm planning on pulling the cylinder head on the engine I'm buying as well so I may go ahead with new studs too. Won't be able to clean it up as well as yours since I won't be completely disassembling it though...
