It is currently Fri Nov 20, 2026 8:05 pm
 Post subject: Engine back in car
PostPosted: Sun Apr 20, 2008 12:18 am
Well, I got the engine back in the car today. Just got it bolted to the tranny and motor mounts on. Still have to hook everything back up and get it running. Had to go pick up a couple motors. A lady on Craigslist had a couple motors for free to anyone who wanted to pick them up, so I couldn't resist. One was just a short block, but the other was complete except for pan and manifolds. She said the oil pump went bad on it so she just pulled it. Had a friend who was a mechanic and got her motors for cheap.When I got them home I noticed the short block was a BH block. Now the bad news. She said it had a bad rod. Well actually it broke a piston and the pin that was still on the rod knocked a nice hole in the cylinder, Damn. Is it worth sleeving? The complete motor looks very clean inside, but I noticed it is a hydraulic cam motor. I think it had a casting date on the side of 10 13 81. Probably a 1981 motor? Let me know if these motors are worth hopping up.
Wylde Bill
63 Dodge 330
00 Sportster Rigid Bobber
05 Dodge Stratus (Wifes)
 Post subject: Hydraulic cam motor
PostPosted: Sun Apr 20, 2008 9:13 pm
I have a question about the motor with the hydraulic cam. Are the push rods supposed to be hollow for the oil to be pumped through up to the top end? I'm not familiar with the hydraulic Slant 6. I know on chevys that is the case. If that is the case, I think I know why there was a problem with this motor. When I looked at the push rods last night, they are solid. I wonder if the mechanic put the wrong pushrods in and that is why they thought the oil pump was bad because you would get no oil to the top end. Or am I incorrect? Any help is greatly appreciated.
Wylde Bill
63 Dodge 330
PostPosted: Mon Apr 21, 2008 4:43 am
Car Model: 1974 W100; 72 Dart
Actually, the oil goes the other way. It takes the same path as the older motors, then DOWN the pushrods to the lifters. This is the source of many ticking valves on high mileage hydraulic slants. Those push rods get clogged up and no oil gets down to the lifters.
sb
PostPosted: Mon Apr 21, 2008 5:14 am
The short answer to the question is yes, the push rods should be hollow.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Apr 21, 2008 11:29 am
Can you put a solid cam in a motor that came with a hydraulic set-up. I know you can do it either way in a chevy small block. I would like to build up this motor since it is so clean, but I haven't seen too much stuff for the hydraulic motors. Also is it a cast crank motor if it is from 1981? On the other question I had, is it worth sleeving the BH block I got?
Thanks all,
Wylde Bill
63 Dodge 330
PostPosted: Mon Apr 21, 2008 12:21 pm
You can change the hydro. lifter engine over to solid lifters, just swap the cam, lifters, pushrods and rocker arm assembly.
As for sleeving the BH block, yes... l have installed sleeves into a few of them but most of the time it is a race prepped block with lot's of time and effort already spent on the block. The basic question: How much $$ to install a sleeve? Around here $100.00 for one cylinder, your area may-be cheaper. How much to find another (good) BH block?
People give those away... :wink:
 Post subject: Rocker arm assy
PostPosted: Mon Apr 21, 2008 4:59 pm
So the rocker arm assy is different. What is the difference? Are there hot cams available for the hydraulic motor?
Wylde Bill
63 Dodge 330
 Post subject: Re: Rocker arm assy
PostPosted: Mon Apr 21, 2008 5:12 pm
The hydro r-arms do not have any adjuster screws and have a cup on the pushrod end to accept a ball tip pushrod. The pushrods have ball tips on both ends... with oil holes to send oil down to the lifters.
Wylde Bill
Yes... but the solid lifter set-up is the better way to go.
 Post subject: Rocker arms
PostPosted: Mon Apr 21, 2008 6:32 pm
This mechanic must have been totally lost, the rocker arms on the motor have the adjusters and it had solid push rods. so it looks like he just had the hydraulic cam and lifters. At least I'm assuming the cam is hydraulic like the lifters. The lifters are definitely hydraulic. He may have put on a head from a solid lifter motor.It is a drool tube head. I may just have to change the cam & lifters then get the couple missing parts to have a complete motor.
Wylde Bill
63 Dodge 330
PostPosted: Tue Apr 22, 2008 8:47 am
What you discribe is a common "screw-up" seeing that everything will bolt together that way... but the lifters will never get enough oil to pump-up.
Are the hydro lifters the "top oilers" or do they have a oil hole in the side?
 Post subject: Top oiler lifters
PostPosted: Tue Apr 22, 2008 11:28 am
They had the hole in the top. That's how I noticed they were hydraulic when i saw the holes and then noticed the wires that hold in the plunger.
Wylde Bill
63 Dodge 330
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
