It is currently Thu Nov 19, 2026 10:44 pm
PostPosted: Wed Apr 23, 2008 8:59 pm
Is it possible to put a forged crank in a cast crank block? I think you have to do some machining to make it work. Am I correct?
Wylde Bill
63 Dodge 330
00 Sportster Rigid Bobber
05 Dodge Stratus (Wifes)
PostPosted: Wed Apr 23, 2008 10:36 pm
Why? The cast crank is plenty strong. What is it you need to accomplish?
PostPosted: Wed Apr 23, 2008 11:19 pm
Yea, the cast crank also has smaller journals and that will allow you to find rods cheap.
Remember the engine in the Mopar Muscle mag ( I believe that was the one) they made 320hp and used the cast crank.
Jess
PostPosted: Wed Apr 23, 2008 11:52 pm
The reason I'm interested in this is because I can get a forged crank cheaper than a cast crank, both remaned.
1973 Plymouth Scamp
PostPosted: Thu Apr 24, 2008 6:11 am
It will not fit though, so savings will be moot. :shock:
It shouldn't be too hard to find a steel crank block.
I've been using a Car Quest reground steel crank in my nitrous motor for years. So far, so good.
One other bit of basically useless trivia, when Mike J ran the first 10 second pass by a door car, he used a cast crank motor. :lol:
 Post subject: Lol...
PostPosted: Thu Apr 24, 2008 7:02 am
I wish you were near me you could have a forged crank block for pretty darn cheap...LOL...
either motor is fine to work with, the added benefit of the cast crank motor is the crank is quite a bit lighter than the forged crank unit, so it tends to wind up faster than the forged crank (this will be moot in day to day traffic , of course...)
PostPosted: Thu Apr 24, 2008 10:13 am
I have a 77-ish block in my car. I found out when I replaced the bearings and the rod bearings were too big. I'm assuming this is probably a cast crank engine now?
1973 Plymouth Scamp
PostPosted: Thu Apr 24, 2008 10:17 am
Yes, the change to cast cranks was mid '76. If you got rod bearings that were too wide that would indicate the cast crank engine. I have some standard size cast crank rod bearings if you need them. Cover shipping and they are yours.
PostPosted: Fri Apr 25, 2008 7:34 am
You're not the first to offer me standard bearings, but I thank you. My crank is already .010/.010 and it needs to be turned again.
1973 Plymouth Scamp
