It is currently Thu Nov 19, 2026 9:34 pm
PostPosted: Fri Apr 25, 2008 10:59 am
Long story short...
In process of working on the interior of my duster. I found an issue with the wheel well (needs a patch) so I need to take to a shop to get new steel welded in. So.. I refilled the radiator to get it running again. Well dumb me did not fill the radiator enough. So got car running, tweeked the carb, and was goin well, then i noticed the temp gauge creeping up. So i shut off. Got new t-stat,inlet housing,gasket replaced them. Started filling it up, and now there was a steady drip of ANTIFREEZE coming from the oil pan. It stopped after about 5 mins. I noticed before the oil pan gasket didnt look good. but never had antifreeze till now.
Any ideas??
Have to say Im gettin real frustrated with this car.. thanks..
PostPosted: Fri Apr 25, 2008 11:04 am
You sure the water pump didn't start leaking and run down the oil pan?
PostPosted: Fri Apr 25, 2008 11:38 am
i guess its possible. just wasnt leaking before. didnt think it would just start now. car was running about 2 days ago. ill have to chek the pump tho. thanks
PostPosted: Fri Apr 25, 2008 12:10 pm
I had a 318 that held its water until I put coolant in it. Then the water pump started leaking. Check the weep hole in the water pump.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 2 guests
