It is currently Thu Jun 25, 2026 11:42 am
 Post subject: From tree to floor
PostPosted: Sun Nov 17, 2002 10:37 pm
Is it fairly simple to convert an A904's linkage from being mounted on the steering column to being a floor mount? I'd like to do this, just for the sake of appearance, once I replace the bench seat with a pair of buckets.
 Post subject: should be easy
PostPosted: Mon Nov 18, 2002 6:22 am
Assuming you want an aftermarket floor shifter (B&M, Hurst...) then it should be a snap. The shifter will come with a cable and brackets to attach to your stock trans shift lever. I am assuming that you do NOT have a '65 car with factory cable linkage, that would be considerably harder, but still doable.
Lou 8)
 Post subject: Re: should be easy
PostPosted: Mon Nov 18, 2002 9:03 am
Lou 8)
It's a 1970 with what looks (in the Haynes manual) like rod linkage. Do the B&M or Hurst kits come with just the shifter itself, or the whole assembly? I'm also guessing I'll have to cut a whole in the tranny hump for this.
 Post subject: Shifter Install
PostPosted: Mon Nov 18, 2002 10:15 am
The aftermarket shifter come as a complete kit. As noted, most have a cable so all you need to do is drill a hole for the cable to go through and also a few mounting holes for the shifter itself.
The factory stuff can also be used but that is a lot more work and requires welding.
PostPosted: Mon Nov 18, 2002 2:15 pm
i have a hurst v-matic II for sale. It comes with everthing you need for the 904 tranny. the housing is cracked, but you can get a new one from summit for 30-35$. I want 50$ plus shipping for it. Thanks.
PostPosted: Mon Nov 18, 2002 10:15 pm
I'd take it but I wanna get the bucket seats in the Dart first, and before those I need a new alternator for my truck :|
PostPosted: Tue Nov 19, 2002 3:54 pm
ok, i just figgered id let you know.
PostPosted: Tue Nov 19, 2002 4:43 pm
I'll give you a holler once I get those buckets in, and if you still have it I'll take you up on it.
PostPosted: Tue Nov 26, 2002 5:43 pm
i still have it and havent had anyone else interested in it. e-mail me at tommyb1515@aol.com when you want it.
PostPosted: Tue Nov 26, 2002 6:19 pm
Sweet, I'll be sure to. I'm hoping to have her buckets by February (in time for her birthday), so hopefully you'll still have it then :p
