It is currently Mon Dec 29, 2025 6:53 pm
 Post subject: engine is done pic.
PostPosted: Sun Apr 27, 2008 8:16 am
I completed my first slant six it has:
8.4 compression ratio .060 of the head
3.460 bore
198 crank and rods
stock pistons with cast rings
Stock cam bumped up to a true .44 intake lift at valve degreed and set 3 degrees retared
stock valves with hardened exhast seats
ported intake and exhast runners
super six intake and exhast gasket mached to head
Carter bbd from a v-8 pre emmissions stuff
Stock timming chain
All for a total of
$275 machining, piston pressing, valve job and mill
$280 Engine rebuild kit with piston and oil pump
$40 Cam regrind
$55 supplies (silicone, paint, ect.)
_____
$650 give or take $20
Not bad for a fresh engine.
Here are some before and after pictures :D
http://i263.photobucket.com/albums/ii13 ... -07020.jpg
http://i263.photobucket.com/albums/ii13 ... IM1978.jpg
http://i263.photobucket.com/albums/ii13 ... IM1977.jpg
http://i263.photobucket.com/albums/ii13 ... IM1973.jpg
http://i263.photobucket.com/albums/ii13 ... IM1974.jpg
1964 barracuda 198 slant
PostPosted: Sun Apr 27, 2008 8:36 am
Online
Nice looking motor! :D
I like that valve cover treatment. :D :D
PostPosted: Sun Apr 27, 2008 9:00 am
Looks great!
You may want to re-think that big steel fan, those "eat" a bit of power and make a bunch of noise. My car actual cooled better at freeway speeds with a smaller fan.
two tone valve cover looks cool, nice job, what is it going in?
:D
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sun Apr 27, 2008 10:49 am
Looks great!
One thing - do you mean the cam is 3 deg retarded from the stock spec?
PostPosted: Sun Apr 27, 2008 10:59 am
very nice engine
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Sun Apr 27, 2008 11:47 am
its going in a 64 barracuda with a 230 3 speed full syncro. its going to be a driver and fun car for my wife to take to local shows. Right now the body is rough but very little rust and I hope to get it painted and start assembly buy late september [/quote]
PostPosted: Sun Apr 27, 2008 12:28 pm
I split the overlap and retarded it three degrees from there to hopefully gain a litle higher end performance. I'm not sure being that it is a small overlap if it will make a bunch of diffrence. I'm just playing with what I have to make the best of it with out laying out the cash for a hi-porformance cam. I also may put automatic in it later if my wife gets tired of driving a stick.
PostPosted: Sun Apr 27, 2008 5:14 pm
Looks awesome!
big fan of the valve cover.
Ian Vatcher
1966 Barracuda/225/2.76/Holley 1920/Stock Exhaust/ 9" Drums
Yah, I could put a V8 in there, but then it wouldn't be a Slant 6 now would it!
PostPosted: Sun Apr 27, 2008 5:22 pm
Nice work, I started my swap in my '64 today. It's inspiring to see it all come together.
PostPosted: Sun Apr 27, 2008 5:32 pm
It feels good to have it all together. But I can't put it in the car for awhile and hear it run. I am debating mounting it to the k member and making and wood frame to start it on the ground so I can break it in and set he valves when hot. But more importantly hear it run.
PostPosted: Sun Apr 27, 2008 6:07 pm
Dude, that motor is F****** BEAUTIFUL.
Great job. Great inspiration! :shock: Thank you.
PostPosted: Sun Apr 27, 2008 6:11 pm
I've been thinking about building a box tube jig that I can use to run and break-in motors for a while now. But the price of steel is so insane that it's probably just worth it to drop it in the hole and fire it up...as much as we hate doing things twice that is. It would definitely put a smile on your face, no question.
 Post subject: nice job
PostPosted: Sun Apr 27, 2008 6:25 pm
Just jumping in. Nice job, I'm thinking of painting my engine body color, and i think the valve cover idea will catch on.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
