It is currently Tue Nov 17, 2026 8:02 pm
 Post subject: Need pictures
PostPosted: Sun Apr 27, 2008 2:42 pm
of how the washers and things are suppose to be put on the engine when installing the exhaust to the block
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Sun Apr 27, 2008 2:53 pm
How about this:
http://www.slantsix.org/articles/manifo ... unting.htm
-Mac
PostPosted: Sun Apr 27, 2008 3:46 pm
see i need up close detailed pics i mean i sorted through all the triganle washer i had two brass one and a few things but some of thosse triangel washer were well thinner than some
PostPosted: Sun Apr 27, 2008 8:08 pm
all the triangles should be the same size and thickness and the brass thick washers go on the ends of the exhaust. but thickness variation shouldnt matter if they are all torqued evenly
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Sun Apr 27, 2008 8:49 pm
The triangle washers came in different thickness' over the years. I think I've found 3 different thickness' so far.
The newest ones are the thickest. My 64 has very thin ones compared to the new ones you can still buy from Chrysler. (Part # 3751 636 - approx. $2.70 each)
Danny
PostPosted: Mon Apr 28, 2008 3:33 am
so do you buy them from the dealer or so on?
PostPosted: Mon Apr 28, 2008 12:02 pm
Here is more detail on how all the hardware installs.
http://www.slantsix.org/articles/manifo ... ctions.htm
As for replacement "spanner washers", they can be purchased new or found used. I pick them up off the ground at the wrecking yards, all the time.
PostPosted: Mon Apr 28, 2008 12:22 pm
what are the conical washers
PostPosted: Mon Apr 28, 2008 1:32 pm
The conical washers are round, concaved on one side, convex on the other.
These are the ones in the middle, left of this photo, just above the tape measure.
PostPosted: Mon Apr 28, 2008 6:21 pm
what are the ones with the nut heads wiht washer bodies for?
PostPosted: Mon Apr 28, 2008 9:41 pm
the one on the bottom right? just looks like a stud wit a conical washer and a nut on the end. or the washer wit the nut on it, that one ive never seen on a slant
PostPosted: Tue Apr 29, 2008 4:14 am
yeah me either
PostPosted: Tue Apr 29, 2008 4:49 am
the circle washers go on the outside (right and left) bolts and all the others ones have triangles at least thats how my cliff intake and headers are together i'll take a picture when i get out of school if ya need
Kev
PostPosted: Tue Apr 29, 2008 10:26 am
will do
