It is currently Wed Nov 18, 2026 1:18 am
 Post subject: carter carbs
PostPosted: Mon Apr 28, 2008 6:34 pm
So, I will be putting a 2 bbl intake and carter carb on the /6, my question is, are all carter two barrells the same flange size? Or is there a bunch of different flange sizes? I thought about buying one off ebay but the guy says it only fits a 318, I thought a 2 bbl was a 2 bbl. Thanks in advance.
PostPosted: Mon Apr 28, 2008 6:45 pm
There are two different flange sizes for the 2bbl carbs. The small one was used on 6-cylinders and small-block V8s. The big one was used on big-block V8s. A 318 carb will bolt onto a slant-6 intake, but there'll be choke linkage issues to work around.
PostPosted: Mon Apr 28, 2008 7:04 pm
when you say work around, how much are we talking? Fabrication? anything specific?
PostPosted: Mon Apr 28, 2008 9:47 pm
if dan is nice he will post the link to the carter manuals. one of them in particlular gets into detail the differences betwenn the 318 and /6 version. the way they explain it seems to be that the 318 version is way ineficiant on a slant. but thats just me talkin outta my @55.
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Tue Apr 29, 2008 6:41 am
No it'll work, but the choke linkage is meant for the 318's choke thermostat not the odd angle of the super six stat... so he'll have to either:
a) use a manual choke cable
b) find a super six carb and swap the part
c) make a workaround
Also some of the carbs have holes in the throttle plates and this may or may not affect the idle/etc... depending on the engine's build
PostPosted: Tue Apr 29, 2008 7:30 am
Carter BBD operation and repair manual (pdf)
Users browsing this forum: Google [Bot] and 7 guests
