It is currently Fri Jun 19, 2026 9:06 pm
 Post subject: LCA interchangeability
PostPosted: Mon Apr 28, 2008 2:06 am
when did the sway bar tabs move? I have seen them mounted in the middle of the lca, and way out by the knuckle and strut rod assemblies...
on a more urgent topic:
are the lower control arms the same on the A vs. B-bodies?
ive got a chance to pull a set with swaybar tabs off of a 68 Coronet Super Bee. but the car is slated to be scrapped soon.
should i spring for it?
(They would be installed in a 73 scamp, BTW)
thanks!
 Post subject: I don't think...
PostPosted: Mon Apr 28, 2008 6:58 am
1967-1972 uses a sway bar that mounted under the K member, and 1973-1976 used a bar that went through the K-member
PostPosted: Mon Apr 28, 2008 7:06 am
thanks!
Sway bar tabs mounted in the middle were used from 65 or so through 72. 73-76 were out by the knuckle.. I looked in my parts book and it shows different part numbers for the A and B body LCAs. I'd still grab them anyway as B Body people are always looking for that kind of stuff (along with sway bars)
PostPosted: Mon Apr 28, 2008 10:07 pm
ive got an aftermarket sway bar, i think from pst... they have the end links attach to a bracket that is bolted through the shouck mount, kinda lame i say, anyways... any way to make one of these stock options work, i didnt know they had lca's wit sway bar tabs already on them....
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
