It is currently Sun Oct 25, 2026 11:07 pm
 Post subject: cooling problem
PostPosted: Sat Nov 30, 2002 1:04 am
Hi
First, I'm sorry, my english is not very good.
My super six has cooling problems. In summertime when the air temperature is high, the engine is running after 20 mile run very hot. It's not boiling if I keep speed under 55 mph. And now wintertime the engine wont get the temperature. It's running cold all the time.
I have changed thermostat, but it didn't help.
PostPosted: Sat Nov 30, 2002 11:19 am
Site Admin
Do a search on "overheating". Julie Roth had a lot of problems with overheating and there are lots of suggestions in that thread.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sat Nov 30, 2002 8:36 pm
I already read everything, but why the engine is not getting the normal temperature at cold weather.
 Post subject: too hot/ too cold
PostPosted: Sat Nov 30, 2002 9:28 pm
If there is sufficient coolant, and the thermostat is the correct value and functioning properly, then I see no reason for it to run too cold.
The thermostat's job is to withold circulation until the specified operating temp is reached.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
 Post subject: Too Cold
PostPosted: Sat Nov 30, 2002 9:32 pm
Is the heater core by-passed? That will keep the engine from warming-up.
If it is not that, then the thermostat is stuck open.
Look inside the radiator when you first start the car, cold. If the coolent is moving in the radiator tank, the thremostat is stuck open.
 Post subject: reversed thermostat?
PostPosted: Sun Dec 01, 2002 7:20 am
If the thermostat is reversed, it may stick too. It should have a marking on it that says "rad" or "head".
PostPosted: Mon Dec 02, 2002 9:23 am
Heater core is not by-passed.Thermostat is not reversed and it's closed when I start motor, so it's not stuck open. Maybe I'll have to clean the whole cooling system.
PostPosted: Mon Dec 02, 2002 10:01 am
What is the correct radiator gap pressure. I have 50 kpa (7 PSI)
 Post subject: should be higher
PostPosted: Mon Dec 02, 2002 12:48 pm
The factory cars, I believe, had a 13-15 psi cap. I run these higher pressure caps and have never had a cooling problem.
