It is currently Sun Nov 22, 2026 5:50 pm
 Post subject: Low/Reverse adjustment
PostPosted: Sat May 03, 2008 9:11 pm
Site Admin
I have a '74 A-904.
The spec for that year's L/R band is 41"# and out 7 turns.
I have installed a Street/Strip Shift Improver. (B&M)
Should the adjustment go to the prior years? I didn't feel slack in the band when adjusted out 4 turns, should this be something in between?
I'm having an interesting situation when pulliing off the freeway after a long third gear haul. The transmission doesn't shift into first. It stays in second even after a stop. I pop it into low (1) and the problem goes away until I've been in high gear for a long period again.
It seems to work fine around town.
Could the loose L/R adjustement have an effect on this? Low RPM, Low pressure, Rear band disengages for second, then doesn't pump up after a short stop to re-engage the L/R band to engage first?
Hmmmm. I feel like a pioneer.
CJ
PostPosted: Sun May 04, 2008 7:13 am
I don't remember ever turning one out 7 turns. Most I recall is 3. :?
Both bands in my trans are tightened finger tight and out 1-1/2 turns. :D
PostPosted: Sun May 04, 2008 8:19 pm
Does that work well?? Isn´t shifting a bit hard?
PostPosted: Thu Apr 28, 2011 8:45 am
Yup, digging it up again.
I have this transmission in my Valiant now. Doesn't seem to matter where the kickdown is really (it is set statically right now) it decides when it wants to shift. Sometimes it will shift 1-2 at 20mph (whichever is what I want) other times it will shift at 25 MPH. The 2-3 shift is what really grinds my gears, because its never consistent.
Right after adjusting the kickdown so that I got the 1-2 shift at 20, it shifted to 3rd at 31. Fine by me. The next day, the 1-2 shift decided to wait until 25, and now I've gone up to 45 with no 2-3 shift. I drove to work this morning in 2nd gear, which, by the way, is horrible on fuel.
What gives?
The bands are adjusted as per the manual posted here on the site in the sticky. The shifts (when they come in when I want them to) are crisp. When they come in later, it snaps my neck, or clunks the 7.25" gears. If I am on power mode, the shifts feel fine when they happen, in granny mode, they smack a bit.
I don't have the equipment yet for the kickdown, my polar cable on the Carb end is looking miserable and I can't connnect it to the Carb yet (Holley 2300).
Any ideas?
~RDE~
PostPosted: Thu Apr 28, 2011 9:26 am
Band adjustment doesn't influence shift timing vs. vehicle speed. Look to your throttle pressure linkage system from end to end; something's AFU with it.
PostPosted: Thu Apr 28, 2011 9:19 pm
@ CJ,
Something is sticking in your trans when hot if it stays in 2nd gear. The
L-R (rear) band doesn't apply unless you shift to manual low. Automatic 1st gear ("Drive" & "2" shifter positions) is the rear clutch pack & the overunning (sprag) clutch. 2nd gear applies the front band, causing the sprag to freewheel. For 3rd the band releases & the front clutch pack applies. So I suspect your governor valve or a shift valve is hanging up, preventing the front band servo from releasing until the manual valve overrides it.
If the L-R band servo & apply lever are stock, then I really don't see much reason not to use the FSM adjustment procedure. Again, the band isn't used normally in Drive range, so having a slightly faster apply doesn't make any sense, compared to having more band wear because it's tighter around the drum when released. You have the same near zero gain when shifting into reverse.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sat Apr 30, 2011 10:16 am
Site Admin
@Wagons,
Look at the date on my post.
I solved that years ago.
CJ
PostPosted: Sun May 01, 2011 9:21 pm
Oops! Guess I weren't too observant. Why not post your fix to the forum?
63 Valiant Wagon
225 - 4 bbl
PostPosted: Mon May 02, 2011 10:43 am
Site Admin
Good idea. We leave all this stuff here so people can search for answers.
Chuck Rivers, Webmaster
Image Image Image Image
Users browsing this forum: Bing [Bot] and 9 guests
