It is currently Sat Oct 24, 2026 1:41 pm
PostPosted: Sat Nov 30, 2002 12:13 pm
Hey everyone...happy saturday (hopefully). Well for me....ehhh..im cooling down right now. Just had a short bout with a cast iron head and guess who won?? Right....not me. Anyway, I got my head back from the machine shop and i'm attempting a reinstall with the engine in the car. Seems nearly impossible. The gasket slips against the block...the head slips against the gasket....and im throwing my back out trying to get it on there. The dowel in the back is almost flush with the block. i'm assuming this shouldn't be the case. Should I pull it out and replace it?? Is that possible?? Should I rent a hoist? In short, what is the best way to do this. i'm using a FelPro Permatorque gasket and it says "use no sealer"...should I?? Hope you guys can help. Enjoy.......
 Post subject: problems?
PostPosted: Sat Nov 30, 2002 12:38 pm
no sealer needed w/ PT gskts. Yeah, i'd use some vise-grips and pull the dowel back up. Don't know what kind of vehicle you're dealing with, but it shouldn't be that much of an ordeal. You need to take a break, center yourself, and become one with the slant, grasshopper.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
 Post subject: 64 valiant 225
PostPosted: Sat Nov 30, 2002 12:41 pm
Hey there....Its a 64 valiant 225. I just cant seem to support the weight and center the head at the same time.
 Post subject: Got it......
PostPosted: Sat Nov 30, 2002 1:44 pm
Hey...found what I needed. My roommate was hungover enough to be persuaded to assist me. Two extra hands really did the trick. So now Im back in business (well,almost). Enjoy......
PostPosted: Sat Nov 30, 2002 7:16 pm
Site Admin
Just a quick note about that locating pin. It should stick up about 1/4". Be careful trying to pulll it out just a bit with vice grips. You will make a groove in the pin and also raise some of the metal. I used vice grips to remove some pins from an old block to put into a block that had the pins remove when the block was cleaned. (Why? I don't know!) I hammered the pins into the new block but the ridges created with the grips prevented the pins from seating properly and I blew the head gasket as a result. It is best to remove the pins and replase with new ones. I had someone take some pins from a Chebby block and grind them shorter to fit the slant.
Chuck Rivers, Webmaster
Image Image Image Image
 Post subject: Head Installation
PostPosted: Sat Nov 30, 2002 9:25 pm
Two good dowel pins is a must. When doing SL6 rebuilds, I spend a good amount of time with those head to block locating dowel pins. (I adjust the dowel pins so the head chambers are well centered over the cylinder bores.)
For a head swap, one trick is to have two 5 inch long pieces of 7/16-14 unc threaded rod to screw into the block. These "studs" will keep the head gasket in place while you slide the head straight down, using the locating studs as a guide to help get onto the dowel pins.
 Post subject: can make 'em too
PostPosted: Sun Dec 01, 2002 7:19 am
I have made dowel pins by cutting down good quality 1/4" (grade 5 or 8) bolts to give ~ 1/2" long pins. 1/4" unthreaded rod works too. Cut the threads and the head off a non-full-threaded bolt. 8)
 Post subject: OK.....Im nervous now
PostPosted: Sun Dec 01, 2002 9:02 am
Well....Of course I've read all of this after the head and rockers are back on. And I wince at the thought of removing it. Although blowing the head gasket is a more disturbing thought. The back pin is about 1/16" out of the block. The front one is about a 1/4". What should I do? Leave it and see what happens or should I pull it back off and start over (OUCH)? Just gonna try and cool the nerves here. Thanks for the help. Guess I should have waited for these responses.
 Post subject: see what happens
PostPosted: Sun Dec 01, 2002 11:36 am
There will probably be no problem here. Just drive it and see what happens. In my early car days, I got a motor back with no dowels and I didn't even notice until I pulled the head off 30k miles later (no problems, just changing things around). 8)
Users browsing this forum: volaredon and 22 guests
