It is currently Mon Nov 16, 2026 9:46 pm
 Post subject: Weber Carb Question
PostPosted: Tue May 06, 2008 3:59 pm
I currently have the ProLine Fuel/Offy dual carb with Webers on my Volare. I've been thinking of switching back to one carb for simplicity, as well as economy. However, I wouldn't mind rejetting/tweaking these two carbs if that's possible.
I can barely see the numbers on the carbs; the first digits look like "36", and then "DNVO", or "DVNO".
I'm gonna check out some websites to see if I can figure out which Weber carbs I have.
Any suggestions on tuning or modifying these carbs will be appreciated.
Thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Tue May 06, 2008 4:51 pm
click a picture or two of this carbs on your slant and post here?
Cheers, Wizard
PostPosted: Sat May 10, 2008 12:20 pm
Another member here who has this same setup identified these carbs as being Weber DCNVH36 carbs.
My slant is mostly stock, I wonder how it would run with using one of these carbs on an Offy 4bbl intake with an adapter plate? I may have to change jets though.
Any feedback is appreciated!:D
'78 Volare 225
'67 Charger 318
PostPosted: Sat May 10, 2008 2:33 pm
How about swapping to a pair of staged Webers? That way you can have 2 bbl economy and 4 bbl performance in the same package.
Setup is still a pain compared to a single carb, though.
-Mac
PostPosted: Sat May 10, 2008 9:31 pm
Yeah, I could probably get that to work, but I'm looking for simplicity in addition to economy.
'78 Volare 225
'67 Charger 318
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
