It is currently Mon Nov 16, 2026 8:05 pm
 Post subject: Carb Dip
PostPosted: Fri May 09, 2008 2:04 pm
So I got my Carter BBD in the mail today and was wondering the best way to clean it. So what is the best way to clean it? I'm going to rebuild it with a NAPA rebuild so should I dip it first? or should I use carb cleaner spray? Should I take off parts and dip? or just do the whole thing? Thanks a lot.
-The man with many questions.
PostPosted: Fri May 09, 2008 2:12 pm
When I did mine I took it apart and dipped it in seperated.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Fri May 09, 2008 3:58 pm
Poser
Damn, I thought this thread was about crab dip! :D Sorry couldn't help it!
 Post subject: Get the kit...
PostPosted: Fri May 09, 2008 4:34 pm
Take it apart and put plastic and misc small parts in a plastic container/ cup... You can then either get a gallon metal bucket and a gallon of paint thinner, or get a bucket and strainer at NAPA with some 'carb dip'...
You will also want to have access to an air compressor and nozzle or some canned air at worst to blow out the passages to make sure there's no gunk in the holes...
PostPosted: Fri May 09, 2008 8:44 pm
Car Model: 1968 A108 225/3 on the tree
don't put any rubber parts in the dip. if u have metal parts where the rubber doesn't seperate, don't dip it. be REAL careful with plastic parts. some of those dip chemicals can render ur parts unrecognizable.
D~~~!
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
2003 Ford Ranger XLT extra cab
1997 Geo tracker(Suzuki Sidekick)
