It is currently Sat Apr 25, 2026 2:42 am
 Post subject: Re: Cleaner
PostPosted: Thu May 08, 2008 8:49 pm
Sam, you know I have already nominated you for perseverence awards, so just keep hanging in there!!!!
I am still young in the game with upgrading to EFI (like lurking here and stalking megasquirt auctions on ebay)
Are you sure that is a good idea? DIY electronics are kinda a crap shoot on Ebag. May I suggest a approved vendor like the one "mad scientist" Matt works for?
Chris'
Autobody
Restoration
Service
PostPosted: Fri May 09, 2008 8:49 pm
Sometimes it is hard to tell the difference between perseverance and subborness. I appreciate the kind words. At the very least someone may learn what not to do. :wink: Nice weather is here, the garage is about done. My achilles tendon is healing nicely, and I should be able to concentrate on the Dart soon.
Sam
PostPosted: Sat May 10, 2008 5:50 am
Out of curiousity, is the DFI system able to fire a coil directly, or does it always need an external module?
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat May 10, 2008 6:31 am
Accel requires an external ignition module. Thanks for the thought though.
Sam
PostPosted: Sat May 10, 2008 6:36 am
Naw, it's easy: Is whatever you're trying to fix working yet?
If so, you're persistent.
If not, you're stubborn.
:mrgreen:
PostPosted: Sat May 10, 2008 7:37 pm
I guess I am stubborn. :wink: You could say I am a man vision. :lol:
Sam
PostPosted: Sun May 11, 2008 8:02 pm
Would reversing the leads on the pickup from the distributor to the ECU be worth a try? It has been stated over and over that reversing this can sometimes make things run better. I think even Rance mentioned that to me Is this just purely a subjective thing, or is there some concrete test I can measure to determine if this helped or hurt? I feel silly for not thinking of this before. Thanks.
Sam
PostPosted: Sun May 11, 2008 9:20 pm
It's not subjective; if there's going to be an effect, the car will run very obviously better with correct polarity.
You still need to put an appropriate coil in there...
PostPosted: Mon May 12, 2008 4:14 am
Thanks Dan. I got the coil, but haven't put it in yet. I moved the car outside and covered it up while working on the garage. Now it is very chilly again, and has been raining cats and dogs for days. Our rain gauge has picked up 8 inches of rain in five days. We have been getting the tail end of those violent, toronado ladden stroms that have ripped the Midwest in the last week. So until it warms up and stops raining, I likely will not even try to get it started, and inside.
The speed shop mentioned is called Maryland Performance here in Gaithersburg. I purchased an MSD coil recommended by them for its low RF interfereance characteristics. It is part number 8207. The counter guy who seems like a straight shooter said they have had this particular coil eliminate interferance caused by canister style Blaster coils.
The bad weather is one reason I have been inside pestering you guys on the Forum. :wink:
Sam
PostPosted: Mon May 12, 2008 10:18 am
When I was 18, I would've said "Perfect weather for cold-start troubleshooting!"
Now I say "Pfft. Wait til it warms up and dries out. Play with trains instead."
Interesting information, and it's certainly plausible. I haven't looked into the EMI/RFI characteristics of the can-type coils. Usually it's not an issue because there's nothing EMI/RFI-sensitive within miles (OK, feet) of the coil on a slant-6, but you've got a great deal of potential electronic noise and sensitivity thereto in your particular car. Can-type coils went out of fashion in the very early '90s.
Sam[/quote]
