It is currently Thu May 21, 2026 8:59 am
PostPosted: Mon Dec 02, 2002 10:38 pm
Alright, I've been thinking about getting a set of stiffer torsion bars for my Dart for a while now. I was originally thinking about getting 383 torsion bars (0.890" diameter), but if a little is good then too much is just right, or isn't it? Is there any advantage to going stiffer than this on a street-driven car? I see that .920", .990", and bars 1" and more are available.
I do plan on lowering the car a bit, atleast two inches, to improve handling. What is best? Will bars that are too stiff just promote cracks in the torsion bar mounts without offering any better handling?
'68 Dodge Dart 4dr Sedan
 Post subject: T-Bars
PostPosted: Mon Dec 02, 2002 11:06 pm
This has a lot to do with the car's weight.
I have the .89 bars in my 66 Dart wagon, that car weighs 3600 lbs and those bars are about right, not mushy, not rock hard.
I have run the 1 inch bar in a 440 powered A-body, 3340 lbs and that car rode like a rock, it handled pretty good but you felt every bump.
How much does your car weight and do you drink hot coffee while driving??
 Post subject: my feelings...
PostPosted: Tue Dec 03, 2002 6:59 am
I put the 0.920" bars in my '64 Dart, which is lowered 1-1.5" from stock height. It is a stiffer ride, but not bad. Car weighs about 2800 - possibly less. I think the car will be less forgiving in turns also if you go too heavy on the T-bars, but I have little personal experience for this. My personal experience has shown that lowering the car reduces the wheel rate (either due to nonlinearity in bar, or susp geometry), so a little extra bar is good in that case. My car got a little more oversteer when I put in the heavier bars too.
Take a look at www.arengineering.com at the T-bar article. He notes that newer passenger cars specify a higher spring (wheel) rate than Chrysler did in the 60s. I think if the Dart were built today, they would probably use the 0.890 on Slants or smallblocks anyway.
I bet if you have a heavier car (late A-body with all the trimmings), then 0.920 would be great for smoothness and handling. I have a set of 0.890s I'll be putting in my daily driver '68 Dart.
Happy handling,
PostPosted: Tue Dec 03, 2002 9:19 am
Thanks for the great info. Yeah, the bars will be going in my '68 Dart 4-door sedan (my only car and daily driver). Now, only if I had some nice weather for working on my car outside (13*F with windchill here near Philadelphia today).
PostPosted: Tue Dec 17, 2002 10:46 pm
Car Model: 1964 Valiant
One of the reasons that Chrysler replaced the A-bodies was owner preference for a rubber damped suspension. The only rubber damping is the control arm bushing. I like this "defect" because the handling can be superior. The A-body had a little more road noise than consumers preferred. You'll feel the higher spring rates in an A-body but the car will handle better than the quieter cars. I think this is one reason the 'Green Brick' is still competitive.
I just changed the tires on my Dart, when the rear wheel was jacked off the ground the front tire was also lifted off the ground. I don't know of any other car from that era which this is true. The A-body is a pretty rigid platform, but it's got more road noise. It's the tradeoff that I like.
