It is currently Sat Nov 21, 2026 5:44 pm
 Post subject: my 61 lancer
PostPosted: Sat May 17, 2008 2:33 pm
ok guys, i finally figured out to post pics!!!! here is my "new" 61 lancer project. heres a few shots, interior just got new carpet(check the am radio). motor pic showing split(homade duals), and my offy awaiting a new eddy 500cfm. motor needs detailed, interior is done, body work almost done, all trim @ bumpers off. almost ready for paint........ss
PostPosted: Sat May 17, 2008 3:00 pm
Sharp!
PostPosted: Sat May 17, 2008 4:44 pm
thnx dan, it wont be as nice as yours, but will be the only one in the shows around here. emsvitil, i like the straight axel look and the 70's look, hi@slow......not low@slow....lol
PostPosted: Sat May 17, 2008 5:27 pm
The slot mags really suit it.
 Post subject: new eddy 500
PostPosted: Wed May 21, 2008 1:57 pm
well, first off, let me say kudos to edelbrock!! i just got done mounting my new eddy 500, and so far...LOVE it.... i got the throttle linkage adapted(a few cuts and tweaks :) ), bolted it down, threw on a new filter, and it fired right up and idled beautifully(w/NO adjustments). i decided to drive it to the gas station(no bumpers, tailights mind you), and give her some premium. i got into it a couple of times to check the kickdown, and it works . i burned some rubber too :shock: (yes even w/those fattys on the rear!!), cant wait till i get an upgraded ignition and 4:10 gears w/sg(so i can sqwauk both fattys. :wink: .........ss
PostPosted: Wed May 21, 2008 2:18 pm
Poser
Nicely done! :D
PostPosted: Sat May 31, 2008 5:54 am
update..... body work finished last weekend. i started the roller paint job yesterday. if any of you havent heard of this, see hotrod magazine's falcon , or moparts thread on this subject. the first coat looks pretty darn good, i think it may have been a little too thick because there were very few runs. second coat goes on today, i did not mask ANYTHING and did not not make a mess !! im using rustoleum satin black, and thinning w/oderless mineral spirits. i think i will sand every two coats because of the lack of major runs. this is more labor intensive, but carefull application will return nice results........cost for entire project :wink: -- $50 -- :wink: ...........ss
PostPosted: Sun Jun 08, 2008 3:24 pm
i put on 3 coats, and wet sanded once. then i used rubbing compound on entire car followed by a coat of cleaner wax. final results- not bad, my wet sanding sux, but its a rat rod, so considering the $50 price tag, im happy. also put my new caps on the slots. reinstalled all trim, bumpers, etc. i just drove it about 10 miles and back, gets lots-o-looks 8) . so i bought this car 2 months ago.....now interior done, body done, needs motor detailed, but a running and stopping(sort of) car...............check the pix.............ss
now, thats a grill
cranked the torsions bars a little more
Image spray bombed the wheel wells for a clean look
 Post subject: 3 more pix
PostPosted: Sun Jun 08, 2008 3:26 pm
this shot will be looking better after i put on my chrome cover !!
PostPosted: Sun Jun 08, 2008 4:54 pm
This car kicks ass. :twisted: 8)
 Post subject: more pics
PostPosted: Fri Jun 13, 2008 1:51 pm
the" Piece de resistance " 8) need some chrome exhaust tips now!!!!!
fattys, chrome, stance :wink:
cleaned up the motor a little..needs some spray bombing...the steering box cleaned up nice... see the big "S"? :)
PostPosted: Sun Jun 15, 2008 12:08 pm
That is a nice ride. I like the wheel and tire combo ! The interior looks really bitchin' to !
Have you had the chance to drive it much with the four barrel ? Sounds like your happy with it so far, keep up the good work !
225, pushbutton 3spd
'63 dodge dart hardtop
PostPosted: Mon Jun 16, 2008 8:35 am
Looks great! Keep it up.
Any chance we'll see you at Pittsburgh this coming weekend for the Slant Race? Greg and the boys will be putting on a nice feed and it should be a great time. Very nice folks and some cool cars coming. I'm driving up from Blacksburg, VA in my '68 Dart.
PostPosted: Mon Jun 16, 2008 12:39 pm
mbiz.......ive havent driven it alot yet, but so far its running good w/4bl. ive no way to tell if the motor has had work, but i doubt it. 3.23 gears help it out of the hole, and i havent even tuned it or set valves, or changed from points to electronic ignition yet. Lou, this saturday morn my family and i will be leaving for wyoming for vacation, so i wont make the pa race. i would however like to be at the chrysler classic at norwalk in sept . the lancer needs brake work and a complete tune up before i would trust it to run down the track, or even drive that far.
PostPosted: Mon Jun 16, 2008 3:21 pm
OK, that's enough excuses for me. :wink: Just thought I'd drop that in...
