It is currently Fri Nov 27, 2026 3:55 pm
 Post subject: 904 gearing
PostPosted: Sun May 18, 2008 7:01 pm
Are there different gear ratios that can be fitted to a 904 Automatic transmission?
If so, how can one calculate what the transmission has for a gear ratio.
Presently I have a 3.55:1 8 3/4 rear end. My goal is to create a taller final ratio by transmission recalibration to improve gas milage.
I know, I can hear you; "just change the rear end". My 904 currently is fitted with a reverse valve body, and needs to be returned to normal operation. In this case a change of transmission gear ratio would be easer if possible.
 Post subject: Re: 904 gearing
PostPosted: Sun May 18, 2008 7:16 pm
There are only two ratio sets available. Through 1980, the ratios were:
2.45, 1.45, 1.00
Starting in 1981, the ratios were:
2.74, 1.54, 1.00
PostPosted: Sun May 18, 2008 7:43 pm
As you can see by the info Dan posted there is no change possible to the final (high gear) ratio of the A904 as it's direct drive. You're stuck with a rear axle gear change, adding an overdrive or changing to an overdrive transmission. The only overdrive transmission that directly bolts up is the A833OD manual 4-speed. Adding a Gear Vendors OD to the A904 is also possible, but expensive.
PostPosted: Sun May 18, 2008 8:04 pm
Go with the Gear Vendors overdrive. It's spendy buy you'll really like it. Your final drive would be like having a 2.77 gear with it.
PostPosted: Sun May 18, 2008 8:23 pm
Maybe I'll liberate two of the 17" wheels shod with P235/65 rubber on the wife's Nitro... That would change the ratio a bit.
What was I thinking... Any damn fool knows that these old three speed transmissions have a 1.00 final drive. Gezz... I must have spent too much time clay baring & waxing the fleet today. Sorry to waste everyone's time.
Smicomatose Maineac
