It is currently Fri Nov 27, 2026 2:57 pm
PostPosted: Sun May 18, 2008 8:42 pm
I just installed a Offy intake with a Holley on a 64 dart with a push button 904. I have not come up with a way to set up my kickdown, if I drive it like a manuel valve body will it hurt the trans???Thanks for the info.
All in a days work
PostPosted: Sun May 18, 2008 10:33 pm
Manually shifting the automatic gets around the functional part of the problem but the trans will still be subject to accelerated wear until you put in a kickdown. How about this one?
PostPosted: Mon May 19, 2008 7:06 am
That kit looks good, a little on the pricey side but I guess if you factor in all the time i will have tring to do that myself its pretty justified. Thanks Dan, I hope to order that up shortly.
All in a days work
PostPosted: Mon May 19, 2008 9:20 am
Well, the less-money/more-work version is here .
