It is currently Mon Jun 15, 2026 3:11 pm
 Post subject: Super 6 Exhaust
PostPosted: Wed May 21, 2008 2:50 pm
I know the super 6 and the standard 6 share the same maifold. When putting on the 2.25 exhaust do you make an adaptor or will the flange for the larger pipe bolt to the manifold. Thank you Steve
PostPosted: Wed May 21, 2008 3:20 pm
Site Admin
It bolts right up! :D
CJ
PostPosted: Wed May 21, 2008 4:12 pm
What is the diameter of the manifold at the flange? 2.25?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Wed May 21, 2008 4:16 pm
The outlet size on a factory SL6 exhaust manifold is 2 inch, sometimes a bit over. It is easy to open them up more with a die grinder.
