It is currently Tue Jun 23, 2026 10:38 am
 Post subject: Fired Up my New Motor
PostPosted: Wed May 21, 2008 5:36 pm
Well it finally had to happen.I got my new motor running on Sunday after 2 years building.Everything went pretty smooth other then one small oil leak at one of the fittings on the remote filer line and was having a hard time getting the timing set because the Mallory distributor condensor hit the block when trying to turn it enough and was afraid to shut it off until it was fully broken in.Going to remove it and relocate the condenser tonight and re-tourque the head and adjust the valves.Ran it at 205 degrees and steady 80lbs oil pressure.Saturday off to the muffler shop to get the pipes bent so I can run it without getting the neighbors panties in a knot.It was very loud.I have posted a vidio on you-tube.My wife took it when I fired it up,It's 10 minutes long (sorry I didn't know how to edit it shorter) I listed it under Slant Six Fire Up.I still have some loose ends to take care of but I should be able to road test it this weekend.Thanks for all the help and advice.I should have it on the chassis dyno by the end of June then it's off to the track! Still need to come up with a better rear-end then the 7 1/4 for now.I just can't see it lasting with hard launches and slicks.I'm pretty much out of money for this project til the fall,still want to install a quick change .I'll post the dyno sheet when I get it done. :twisted: :twisted: :twisted: :twisted: :twisted: :D
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Wed May 21, 2008 5:47 pm
Good news! and great going....
What year is your car? so I can find it on You Tube. There are allot posted under Slant Six fire up.........
PostPosted: Wed May 21, 2008 6:27 pm
can't find the vidieo.
1964 barracuda 198 slant
 Post subject: Fire Up
PostPosted: Wed May 21, 2008 8:09 pm
I just posted it late this afternoon.You-Tube said it could take approx.6 hours to load,goota remember it was 10 minutes long.Sure wish I was better with the computor.It should be there tomorrow.It's a 1978 Volare.I put in Automobile,Slant Six Fire Up.Just got done re-tourquing the he=ead and setting the valves,everthing loooked good.Need to remove the dist. tonight so I can modify it in the morning.Can't wait for the exhaust so I can get it tuned propery.
PostPosted: Thu May 22, 2008 5:58 am
Congrats! Sounds good (gotta love open headers)! Can you tell us (or remind us) about the high points of the build? Cam, intake, carb, etc.
Also, what radiator hose did you use that works with the aluminum radiator?
Good luck with tuning!
vm
PostPosted: Thu May 22, 2008 4:34 pm
It's a BH block,forged crank,105 over custom Ross pistons,custom Schnieder cam,custom Manley S/S valve,fully machined head and block,seriously reworked head,Virous fan assembly,all ARP fasteners, Clifford intake,reworked Holley 390 carb.Hooker Pro-Compp header,full Mallory Hyfire VI inigtion,T&D Roller Rockers,727 Specilites reverse valve body trans,(thanks Slantzilla),complete race fuel system ect....
The upper radiator hose? I took a 18"piece of heat riser tube and formed it to fit the profile and brought it to Carquest and ordered everyone that looked right and fit them.Had to trim the ends but it fits great.PM me if you need the part # and I'll dig it up.I had gotten Sprectra metal hoses but the didn't fit good and we cheaply made. :D
PostPosted: Thu May 22, 2008 9:50 pm
emptypockett,
Thanks for sharing! Sounds very smooth.
Are you going to run duals with mufflers and cut outs?
Which Schnieder cam did you go with?
PostPosted: Fri May 23, 2008 10:53 am
sound great! has some good throttle responce.
Thanks for keeping me motivated to finish my car.
joe
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
