It is currently Sun Jun 14, 2026 12:45 pm
 Post subject: AC Evaporator Adapters
PostPosted: Thu May 29, 2008 2:11 pm
Where can I get adapters to use my old evaporator and its male flare fittings with new-style hoses using O-ring fittings?
I'm piecing together an AC system from the old aftermarket setup and some new components. I like the old under-dash unit, and would like to keep it.
I've found sort of the reverse of what I need - adapters that allow the use of compressors having O-ring fittings and the older flare hoses.
PostPosted: Fri May 30, 2008 11:51 am
I have never seen adapters for this, but you can get old flare style fittings that crimp onto the new barrier hose. It will not cost any more than putting together a new style hose. You can even go with the modern fittings on the under hood side and the flares for the evaporator side, really whatever you might need is out there.
PostPosted: Fri May 30, 2008 1:02 pm
Try classic auto air, they did a real nice job with the custom hoses on my 67 GTX, real nice people ,that want to give you what you want
Donnie :)
