It is currently Thu Jun 18, 2026 8:50 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Fri May 30, 2008 4:26 pm
Car Model: 65 Valiant 2 door, 65 Valiant 4 door
heh, sounds kinda like what I did with my exhaust.... kinda but not really close at all. I had a crack all the way around the manifold and had to weld it back together with a stick welder (all I had access to) and the flap inside the manifold never worked very well after that so I just welded it in place. takes a bit longer to warm the carb up enough to idle without the manual choke I rigged up but it works very well. I also saw a 2 mile per gallon increase in efficiency after that too.
65 Valiant 4 door 3 on the tree 225 /6
65 Valiant 2 door Auto 225 /6
Users browsing this forum: Amazon [Bot] and 1 guest
