It is currently Sat Jun 13, 2026 10:00 pm
PostPosted: Mon Jun 02, 2008 3:40 pm
well my rust pit is getting quick fix tix screw job patch pannels w/caulking on edges...what type of paint/undercoat is good on th einterior...any help would be apericated. thanks
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Jun 03, 2008 9:48 am
The Tidewater Mopar Club has used POR-15 on the topside of the floors of our giveaway cars and it's works very well.
I'd advise to make alternating layers different colors, if possible. I wrote up my experience at http://www.tidewatermoparclub.com/TECH/tech5.html
PostPosted: Tue Jun 03, 2008 9:53 am
I've used Ospho and POR-15 in the past.
I recently started using ZeroRust due to it not being as hazardous to use like some of the other rust neutralizers on the market.
http://www.zero-rust.com/
With any of the rust neutralizers, they should be top coated with whatever paint you choose. They all work well on metal that has rust. If you have any bare metal, use an etching primer, then paint.
Slant Cecil
PostPosted: Tue Jun 03, 2008 11:02 am
I've heard good stuff about Eastwood's Rust Encapsulator paint. That's what I plan on using in my engine compartment, undercarriage and all interior metal after rust removal.
PostPosted: Tue Jun 03, 2008 11:29 am
that zero-rust says it can withstand 2000 hours in a salt bath ! looks like six...12 oz cans delivered for $48 sounds good 2 me.
slant six's RULE!
PostPosted: Wed Jun 04, 2008 1:16 pm
I think the reason for top coating the POR-15 like products is they are susceptible to brake down by UV rays. If the coating is not exposed to the poisonous rays of the sun, such as under the rug, or in the trunk one could skip the top coat. Otherwise follow the directions on the can.
 Post subject: change in $$
PostPosted: Wed Jun 11, 2008 1:53 pm
gona use undercoat. $$ factor..a friend use it in his chevelle resto and says no problems..
slant six's RULE!
