It is currently Mon Jun 15, 2026 3:11 pm
 Post subject: ignition question
PostPosted: Tue Jun 03, 2008 6:07 pm
Would it be ok to run an electronic distributor on my slanter? I'm just gettin ready to pick up the truck tomorrow after about two years of being in the shop. So I have very little experience in the slanters but I know well enought they were the best engines ever built. But back to my question i've seen them for sale here and there and was thinking about converting it to electronic and try to get some better gas miles. If yall have any more tips to improve the mpg's I would appriciate the help because I would hate to sell this truck because of somthing that simple. :cry:
1980 dodge custom 150, 225 slanter, four on the floor, restoring lil by lil. So far the engine has the clifford intake and headers, holley 390cfm vacuum secondary, all stock from there.
PostPosted: Tue Jun 03, 2008 6:13 pm
Here is a good place to start:
http://www.slantsix.org/forum/viewtopic.php?t=15779
PostPosted: Tue Jun 03, 2008 6:23 pm
Here's the one I was looking for on gas mileage:
http://www.slantsix.org/forum/viewtopic ... highlight=
There are many others. When you get done with those, do a search for keywords: mpg gas milage fuel economy
Danny
 Post subject: 1980?
PostPosted: Tue Jun 03, 2008 6:41 pm
If it's a 1980 it will either have EI already or have the old 'ESC'/Lean burn system...
good luck on your quest,
PostPosted: Wed Jun 04, 2008 6:31 am
Thanks for the replies i'll be getting the truck this evening and I will double check everything to refresh my memory... if it already has an EI distributor can I hook up an aftermarket control box to it? I honestly can't remember seeing any wires coming out from the distributor. It has the vaccuum advance on it.
PostPosted: Wed Jun 04, 2008 4:42 pm
can I just hook up a control box like an msd 6 box?
PostPosted: Wed Jun 04, 2008 6:36 pm
You can no matter wwhich distributor it is, but if it the old lean burn ESC setup the distributor is looked out and has no advance.
Which now that I think about it you said it has a vacuum advance and unless I am remembering wrong the lean burn system had no advance on the dizzy. In that case yo just hook the pickup of the distributor ( two wire plug) up to the 6AL just like there instructions show. They even have that dizzy shown in there hookup instructions and it would go to the crank trigger wiring on the MSD ( purple and green if I am remembering right).
That the exact way I am running mine and outsides of the cost of MSD its hard to beat it.
Jess
 Post subject: SL6 with MSD 6al
PostPosted: Wed Jun 04, 2008 11:45 pm
I also ran a MSD 6al box in my 225,with the M.P. distributor.Worked great ,I highly reccomend it,very easy to install with the enclosed instructions.Don't forget to open your spark plug gap to .045/.050 for better burn/more mileage(1-3 more m.p.g.) check out the "engine" threads a fewpages back for distributor advance curve "fine tuning" and get even better gas mileage out of your D-150.At $4.00+ per gallon,we need to use "every trick in the book! Warren@PDX.com
"Faith in Science"
PostPosted: Thu Jun 05, 2008 9:55 am
No need to buy an expensive MSD box with a spotty reliability record; much less costly and more cost-effective is the see HEI upgrade.
