It is currently Sat Nov 14, 2026 3:36 am
 Post subject: horn problem
PostPosted: Sun Jun 01, 2008 7:06 pm
Does anyone have a wiring diagram for a '78 D100? Having problems with the horn. I want to see if there is a relay in the circuit. I metered out what I could and found that the sandwhich swich in the steering column was bad (separating foam turned to powder in the last 30 years!) Right now I only make the ground with a test light on certain steering wheel positions. Is this the roller or contact plate acting up? Mike
Good gun control is hitting your target repeatedly
PostPosted: Tue Jun 03, 2008 10:05 am
Fellow slanter wjajr led me to this site: www.mymopar.com/wiringdiagrams.htm
Hope it helps you!
Chris'
Autobody
Restoration
Service
PostPosted: Wed Jun 04, 2008 9:16 am
Also, you might check that the jumper wire that grounds the column to the dash is still there and in good shape... it usually is right at the clamp that holds the column to the dash.
 Post subject: This should be a sticky
PostPosted: Wed Aug 18, 2010 3:11 pm
if it's not already.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
 Post subject: horn stuff
PostPosted: Fri Aug 20, 2010 4:45 pm
Yes there is a horn relay. Not listed in haynes or clymers. on my 78
it was on lthe left hand fenderwell.Depending on contact ring a
spring from a bic click a poprivet just the round part not the
nail. A soldering iron and a short chunk of 16 gauge. Solder
wire to mushroom and bottom of spring. Contact strips in
horn get grody a little soft pencil eraser will clean it. WHITE
wire 18 or 20 ga.is trigger to relay or same ga. yellow some
times. Relay may be plug in or eyelet terminal. All I got.
lol shadetree
brass handled wrench,bfh and a BIG screw
driver. If it aint drawn blood you aint done.
PostPosted: Fri Aug 20, 2010 6:03 pm
I meant this, sorry.
http://www.mymopar.com/wiringdiagrams.htm
,Cliff
'72 4 dr Dart
'63 4 dr Dart
