It is currently Mon May 25, 2026 10:13 am
PostPosted: Thu Jun 05, 2008 6:21 am
80's 904 in a '65 dart. The threads on the speedo cable are slightly different than the threads on the speedo head under the dash. How do I mate them? Thank you for your time. RR
PostPosted: Thu Jun 05, 2008 10:02 am
The speedo cable needed for this swap is a '66-'67 item. ATP #Y803. You can get it at www.rockauto.com if you can't find it locally.
PostPosted: Thu Jun 05, 2008 10:11 am
Does the 904 have the plastic or die cast alum. speedo gear holder, down at the tranny?
Use a 1966 A-Body cable assembly, with the die cast speedo gear holder and all will be good.
PostPosted: Thu Jun 05, 2008 12:49 pm
it has the plastic & I have a alum ones in my stash.
PostPosted: Thu Jun 05, 2008 5:38 pm
I found the alum one & a speedo cable from a parted '66 val & both ends fit. Life is good. it's not what you know it's WHO you know . Thanks guys. now I can find out my mpg :wink:
Users browsing this forum: Ahrefs [Bot] and 7 guests
