It is currently Sat Jun 13, 2026 6:24 pm
 Post subject: Stupid ignition ?
PostPosted: Thu Jun 05, 2008 8:50 pm
Ok well today I tried to fine tune my baby but just can't get her to run smooth. I figured I would try the timing...tag says it should be at 12btc??? I left it at 12' advanced but its just so rough. It back fires alot and seems to run kinda rich. But if I advance it to 20' it runs much better but still has a lil pop, pop, pop, to it. i'm sure i'm doing something wrong. I adjusted the carb the best I could it seems like its in the timing. I'm running a clifford intake and headers, holley 350cfm with vacuum secondary.
1980 dodge custom 150, 225 slanter, four on the floor, restoring lil by lil. So far the engine has the clifford intake and headers, holley 390cfm vacuum secondary, all stock from there.
 Post subject: Mech valves?
PostPosted: Thu Jun 05, 2008 9:34 pm
If your truck has the adjustable rocker arms (not the hydraulic versions), then a valve lash is in order, then adjust timing... (did you say your distributor had a vacc. advance, too?)... another thing to ask is do you have a dial back timing light and a vacc. gauge? You should tune for max vacc. and see where the timing is (I wonder if the vacc. adv. is hooked to the right port... if it's hooked to the metering block on the Holley, it's in the right spot... if it's hooked anywhere else... you'll be maxxed out on vacc. adv. and that's the problem there...)
try some of those and see what comes out...
 Post subject: Re: Mech valves?
PostPosted: Fri Jun 06, 2008 8:23 am
Will do... I think once i'm finished with everything i'm taking it in for an alingment so i'll get everything fine tuned there. thanks for the response!
