It is currently Sun Jun 21, 2026 9:38 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Thu Jun 05, 2008 12:08 pm
Hum Thanks Dan
Im wondering if the light wieght plastic halogen bulbs wont be better???
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Jun 05, 2008 1:18 pm
Well, again, it depends. What's your power consumption limit? Size/shape limitations?
PostPosted: Thu Jun 05, 2008 6:27 pm
SSRN National Champion
Sorry not to get back quicker. Yes the rear light I want would be behind the back glass like a third light. Cant use tail lites for another reason. Dan is the third light led on your site is all I need or do I need a power pak. I want something I can turn on and make a run then turn off. But me being a dumb butt if I was to leave it on a while it would not damage it. Thanks Ron Parker :D
I Might See The Lite But It Aint Over Until I Win
PostPosted: Thu Jun 05, 2008 8:15 pm
You could run these all day and all night and after a lonnnnng time your battery would run down, is all. The 3rd brake lights on my site are meant to be run off the car's battery and/or electrical system. Just hook it up to any 12-14v source and it'll be fine.
PostPosted: Fri Jun 06, 2008 6:27 am
Dan
Size and shape limits... I would guess I would mount mine in the space the old headlights were in. Power consumption 5 amps or less would be great. Also a switch to control it. For some reason the switchs seem to be junk today also.HUMMM
Thanks
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Jun 06, 2008 8:31 am
Well, what's in the headlamp space now? Some kind of blockoff plate? Can't imagine it's an uncapped "sugar scoop" hole (bad aerodynamics). If it is a blockoff plate, make the necessary hole in it and put that round LED reversing lamp in that I linked to above. Switches off the shelf from most auto parts stores are Chinese garbage (big surprise) these days, but good switches can be had. What kind do you want?
PostPosted: Fri Jun 06, 2008 3:22 pm
Thanks Dan I will pm you thanks Ron Parker :D
It Aint Over Until Everybody Sees The Rear Lite
PostPosted: Sat Jun 07, 2008 3:02 am
Dan
I guess either SPST OR DPST non iluminated. Nothing fancy, sent you a pm.
Thanks
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Jun 07, 2008 9:23 am
Got your PM about the carburetors (working on it). Was there a separate one about switches and lights?
