It is currently Tue Jun 02, 2026 2:46 pm
PostPosted: Tue Jun 10, 2008 12:08 pm
I have a 1973 Plymouth Duster. The drivetrain is all stock and I am looking to boost the power. I just want to be able to turn the tires over at will. It is a 225 slat 6 with 3 on the tree. I am looking for a way to beef up the motor for less than $1000 (getting married soon) any ideas or recomendations? Thanks
Steve Brickner Jr
PostPosted: Tue Jun 10, 2008 12:46 pm
Welcome...
Do you know the rear end's gear ratio?
The 3-speed is a handycap, you would have alot more fun if you change it to a 4-on-the-floor (833) transmission.
Have you done a tune-up and valve adjustment?
Fast distributor advance can really help.
Does the car have anti-sway bars? Do you like a car that corners well?
After the above, a "Super Six" 2 bbl and improved exhaust flow would be good "power improvements".
PostPosted: Tue Jun 10, 2008 2:01 pm
Im not very mechanically inclined so I'm not sure whats all been done, I know its been tuned up. I've had the car for about 7 years and put about 10,000 miles on it. How much would a super 6 upgrade cost me and could I get by with the 3 speed? How can I tell what rear end I have?
Steve Brickner Jr
PostPosted: Tue Jun 10, 2008 3:07 pm
The three speed should get you by, I eventually switched to the four speed overdrive unit. The two barrel won't cost much to convert over, look on e-bay and it should cost around 150 for the whole procedure. I just sold my last one to Steph, so can't help you to much there. Assuming your not to mechanically inlcined does that mean you don't have tools? I would look at pulling the radiator and switching out to a more aggressive cam, have your head shaved, get a good ignition and headers and your money should be spent. Take care and good luck!
PS welcome to the board!
PostPosted: Tue Jun 10, 2008 3:38 pm
3 on the tree sucks. Eventually that linkage will give you lots of problems. There is no way to mount a floor shifter with that tranny AFAIK. Just pulled mine out.
Another type 3 speed should have the mounts.
If you wanna teurn over the tires? Put your foot half way to the floor and side step the clutch :lol:
PostPosted: Wed Jun 11, 2008 6:05 am
No Clutch its an auto. I can Brake Stand it but thats it.
Steve Brickner Jr
PostPosted: Wed Jun 11, 2008 7:03 am
Welcome Steve
OK its NOT a 3 on the tree its an auto on the colum. Will most likely have a 2.76 rear end. See your in better shape than you thought.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
FYI: you have an automatic on the column, not 3 on the tree.
Chris'
Autobody
Restoration
Service
PostPosted: Wed Jun 11, 2008 7:07 am
Remove the rear brake shoes
Kip-on-Truckin'
1965 Valiant wagon Turbo slant (work in progress)
2000 Chevy 155" cargo van - The Abductor
1970 Newport convertible
1996 Buick Roadmaster Wagon
1966 CruiseAire motor home
1990 Toyota 1 ton box truck TURBO slant (scraped)
PostPosted: Wed Jun 11, 2008 10:46 am
A good torque convertor woudl help a lot.
Also I think pulling the head and milling it .100, a new cam (keep it small) and 2 1/4 exhaust with a good muffler would be the best way to go.
These little things can transform a slant six. Take your time and find a super six on a old car somehwere cheap and forget E-bay.
At this piont, you will have spent your money. When you have the head milled you want them to do a angled valve job also.
You can tune your factory carb and get a lot out of it untill you find a SS. Also tune the distributor curve ( both cheap upgrades).
The exhaust. the head work, and the convertor are the things that will make the most diff.
Jess
PostPosted: Wed Jun 11, 2008 10:52 am
.... And a lower rear end gear ratio, especially if the car currently has a 2.76 ratio in it.
PostPosted: Wed Jun 11, 2008 12:15 pm
smbrickner,
I have a 1973 Plymouth Duster. The drive train is all stock and I am looking to boost the power. I just want to be able to turn the tires over at will.
If you have a 2.76 gear ratio, do a search on "engine builds" and look for mine on "torque and mileage build". I have an automatic also plus a 8 3/4 posi-traction rear end with P235 tires. I can break the tires loose at will.
It may be possible to recurve your distributor to get some of the punch your looking for and a comprehensive tune up. You will have to do some research and good planning to maximize the $1000 budget. Knowing the condition of your motor and the parts that are on it will go a long way in putting a good plan together.
If you can't find the build sheet and tuning instructions, send me your email.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
